FFS!!!! Front Splitter
Post Mon May 07, 2012 9:46 am
Yes, the brass ring should be lightly greased.
Push a bit of blutac into the hole in the centre of the steering column.
Post Mon May 07, 2012 9:50 am
Brianmoooore wrote:Push a bit of blutac into the hole in the centre of the steering column.
Brian, your really going to confuse him with that old trick :D
adit
Post Mon May 07, 2012 10:05 am
i do hope that's genuine BMW OE blu-tak you're referring to Brian
[quote="bss325i"]
hennared323i
Post Mon May 07, 2012 1:33 pm
I'll get me coat then
Post Mon May 07, 2012 2:18 pm
hennared323i wrote:I'll get me coat then
There is a bush there as you say, and it could conceivably wear and make a noise, but it's a long way down the list of probables.
sunnyr83
Post Mon May 07, 2012 3:03 pm
What's the deal with blu-tac down the hole??
Will that stop the noise?
Post Mon May 07, 2012 3:06 pm
sunnyr83 wrote:What's the deal with blu-tac down the hole??
No, its for hiding your Hash :mad:
Topblag
Post Mon May 07, 2012 3:13 pm
Surely you mean underneath the badge in the middle of the steering wheel winkeye
1984 Hartge H35 in Black
2006 Audi S6 V10 in Black 58k
Post Mon May 07, 2012 3:20 pm
Sorry Colin, but i knew someone with experience would come along to confirm :mad: winkeye
318isPMK
Post Mon May 07, 2012 3:59 pm
Yeah the bluetak is confusing me a little :) but thankfully I don't have access to a socket set this weekend so I'll sort it next weekend. Just in from giving it a good clean it's looking good so the only job I see to do is the steering wheel.
Oh no actually I wonder if there's something obvious that causes a vibrating steering wheel. I have had wheels balanced and tracking done and had a track rod changed and had column straightened but I'm still getting vibrations and feedback when on motorway around 60mph to 70mph nothing wrong when braking... Discs aren't much used all I can think is they may be warped but I'm at a loss. Any idea's p.s it's a niggly problem but I'd like to fix it.
TouringTash
Post Mon May 07, 2012 5:51 pm
come on Rav put the guy out of his misery of tapping his head working out why eh?
Have you had the front in the air/ well secured/ a pal ready to assist, then get underneath and give everything a good wobble and see what is amiss.
If you can get to Brands Hatch I'll be happy to have a look.
318i Touring
318isPMK
Post Mon May 07, 2012 6:01 pm
Brands hatch lol I'm in Glasgow :)
Dezzy
CR24v it's a lifestyle
Post Mon May 07, 2012 8:09 pm
Who balanced the wheels and how was it done.
Sounds like a wheel balance issue to me. That our your tyres are starting to castleate. Either way it should have been fixed or pointed out to you when the wheels were on the balancer.
Post Mon May 07, 2012 8:53 pm
318isPMK wrote: I'm still getting vibrations and feedback when on motorway around 60mph to 70mph nothing wrong when braking... Discs aren't much used all I can think is they may be warped but I'm at a loss. Any idea's p.s it's a niggly problem but I'd like to fix it.
Definitly your Wheels, i put money on them both or one front being buckled,
Best way to find out, if they've all been balanced, is swap the front 2 with the rear 2 and report back.
Dezzy
Post Mon May 07, 2012 10:20 pm
If his wheels are bladly buckled, he'd feel it through the steering at a much lower speed than 60+ mph.
They can be slightly out of shape (most are) and still balance up!
Its still worth swapping fronts to rears and see if its any better. Cheap fix if it is. Maybe ask someone to help you with jacking it up though 8O winkeye
Post Mon May 07, 2012 10:23 pm
True Dezmoundo, but i think they'll be slightly out of shape.
Like I said, swap the fronts and rears, and report back.
And take care when jacking up the car :mad:
318isPMK
Post Mon May 07, 2012 11:03 pm
WARNING-important safety notice
Do not use this manual unless you are familiar with basic automotive repair procedures and safe workshop practices.
I didnt even get past the first line of the Bentley manual lol :)
Dezzy
Post Mon May 07, 2012 11:05 pm
It's probably for the best IMO
snakebrain
Post Mon May 07, 2012 11:10 pm
Buy a shitter for £200 and a socket set then take it apart. You'll learn everything you need to know for cheaps..
Post Mon May 07, 2012 11:12 pm
Dezzy wrote:It's probably for the best IMO
AGREED :mad:
