The other pressure plate was fine, what could have caused this? can I clean it up on a surface grinder? Not sure how good the finish has to be, looks lapped but that could be caused by the rubbing over the years?!?
Cheers dude, got my eye on that already.
what sort of figure is a full re-build from your self? just for furture refgareth wrote:PM'd
Entirely saveable, i see loads like this. All too common with E30 LSD's now.
Surface grind, polish, new plates and as a result of the debris in the oil, all new bearings probably.
The bearings are when it gets tricky so unless you're a competent engineer it's best left to someone who knows how to carry this work out... like me
Cheers Gareth, pm recieved, read and hopefully understood!!gareth wrote:PM'd
PM on it's wayrich318i wrote:what sort of figure is a full re-build from your self? just for furture refgareth wrote:PM'd
