335i Lazur Blue Moredoor - Borbets on all Road Legal P12
johnl320
Post Thu May 03, 2012 9:21 pm
That'll do mate, lots of redundant auto wires, but so what. Its what I used, if you have a manual TPS you will have to change plugs on that loom
leeparkes
Post Thu May 03, 2012 9:22 pm
Yes it will fit being from an E34/32 but it may have the later C101 plug.
Post a wanted on 5 forum someone's bound to have one and it wont cost you £50
johnl320
Post Thu May 03, 2012 9:23 pm
Send me you email and I'll send you an e32 wiring loom file, I found it very useful.
leeparkes
Why dont you place the M20 loom over the engine and see whats what? Might be an easy swap.
Post Thu May 03, 2012 9:26 pm
Who's done the M20 loom swap on here, can't remember
Post Thu May 03, 2012 9:28 pm
leeparkes wrote:Why dont you place the M20 loom over the engine and see whats what? Might be an easy swap.
i was thinking that, if i use an m20 loom surely i wont even need to cut any wires ???
if anything needs extending i can do that using the crap loom
leeparkes
Post Thu May 03, 2012 9:31 pm
Rav335uk wrote:Who's done the M20 loom swap on here, can't remember
There's been a couple but i cant remember who they are, iirc that jaffro did it. (or it could of been Ric) :mad:
Post Thu May 03, 2012 9:35 pm
leeparkes wrote:Yes it will fit being from an E34/32 but it may have the later C101 plug.
Done :D
Post Fri May 04, 2012 7:53 pm
Right wonder if someone can clear some confusion up
ive got a decent c101 connector from an m20 however do i wire it up color for colour ? or does someone have a list of what colours go to what, the one in my other thread confused me as all the pin numbers and colours were different. i didnt want to go of the connector i cut off as i'am not convinced the wiring is correct as the rev counter didnt work and i had 3/4 of tank fuel but light was one. half the crimps just fell of and some had allready came apart, how it ran i would never know. might be half the reason it sometimes runs iffy and sometimes perfect
Reason i havent got a new loom is because i looked at my bank balance this morning and need to leave some money for the rest of the month :mad:
Got plenty of heat shrink and bmw fabric tape so shouldnt look too shabby when done :D
johnl320
Post Fri May 04, 2012 10:00 pm
I would first identify what colours to what pins you have on the car loom side of the C101
The file I sent you has all these wires on it mate, Don't forget you only need 5 or 6 connected to make it run.
Post Fri May 04, 2012 10:01 pm
are these 5-6 connections the basics ? do i need to connect more for other things to work ?
i was looking at your picture, ideally a few close ups of that would do the trick :D :D :D :D
johnl320
Post Fri May 04, 2012 10:12 pm
The wire colours in the picture of the engine loom I posted will probably be the same or very similar to what you have on your loom, but my car is a late chromie so is one of the first models to actually have a c101 so the pin positions are more than likely to be different. I will do some digging
Post Fri May 04, 2012 10:14 pm
Thanks i really do appreciate it, i just want it all right, so everything is as it should.
I'am hammering the search button with m30 and wiring :mad:
johnl320
I have moved pins in the actual engine side socket so not to butcher the car side of the loom. If you know what I mean
i got ya :D
to be honest the engine i took the c101 plug off was a manual moredoor 325i on a G plate and thats what its going into, so i assume all the pins would be correct for the shell.
Its a case of what wires go with what colours on the m30 loom
johnl320
Post Fri May 04, 2012 10:30 pm
On the wiring diagram I sent you the c101 is called the x20 connection. If you look at the charging section you will see a blue wire going through the x20 on pin number 1 this is the alternator feed. You need to confirm it is on pin one on the car side of the loom. So thats your first one, solder that one back on the loom.
Post Fri May 04, 2012 10:41 pm
ive managed to figure this out from various places on the net
E30 from wiki
Pin Colour Function To Image
1 Blue Charge light pin 16 blue plug inst cluster
2 Green/Yellow Static oil level Pin 16 check panel
3
4 Brown Temp gauge pin 26 blue plug inst cluster
5 Brown/Green Oil Pressure light pin 18 blue plug inst cluster
6 Green/White Oxygen sensor relay Fuse 9
7 Green Switched power Ignition switch
8 White/Black Fuel rate input pin 11 blue plug inst cluster
9 Black Engine speed input pin 7 blue plug inst cluster
10 Blue Dynamic Oil level pin 20 Check Panel
11 White/Green Reset service lights pin 22 blue plug inst cluster
12 Grey Check Engine indicator Check Light
13 Green/Purple fuel pump relay fuse 11
14 Black/White Speed signal out pin 10 white plug inst cluster
15 Black/Green Unloader relay pin 1 blue plug inst cluster
16 White/Black Diagnostic connector Diagnostic plug pin 6
17
18 Black/Yellow Start Ignition switch
19
20 Red/Yellow ABS power ABS control module
e34 from some random site
The E34 uses a round style connector to plug into the fuse box. This has 20 pins so I will list what the wires in each of those do.
Pin 1, BU goes to the alternator. Comes from the Instrument Cluster "charge indicator" light. BU in the fuse box.
Pin 2, GN/YL comes from oil lever sensor. It is BU/BK in the fuse box and runs to the static oil level active check control unit, which is the same as the oil level light.
Pin 4, BR/VI comes from the coolant temp sender unit. It is BR/VI in the fuse box and goes to the Instrument cluster temp gauge.
Pin 5, BR/GN Oil pressure switch. Runs to instrument cluster oil pressure light.
Pin 6, GN/WH goes to the O2 sensor heater relay. Gets power from fuse 9 and in the fuse box is colored GN/YL.
Pin 7, GN comes from the ignition switch and goes to the Start Input, in the motronic unit and it also goes to Pin 15 on the coil. In the fuse box it is colored GN.
Pin 8, WH/BK comes from the motronic unit "present fuel rate output". Is YL/WH in fuse box and runs to Fuel Economy Gauge in the bottom of the tach.
Pin 9, BK goes to the ECU Engine speed output. This is BK in the fuse box. On the E28 this actually should be the connected in C103.
Pin 10, BU comes from the oil level sensor. It is VI/GN in the fuse box and goes to the active check control unit as the dynamic oil level light.
Pin 11, WH/GN comes from Pin 7 of the diagnostic connector. Is WH/BU in the fuse box and goes to the Service Indicator Processor.
Pin 12, GY comes from the ECU and is the trigger for the "Check Engine" light control. In the fuse box it is BR/BK. This wire is not used on the E28, since there is no check engine light.
Pin 13, GN/VI comes from Pin 87 of fuel pump relay. Is VI/RD in fuse box and runs to Fuse 11.
Pin 14, BK/WH comes from motronic unit "Speed Signal Input". Is BU/YL in fuse box and goes to the Speed Input of the Instrument Cluster.
Pin 15, BK/GN comes from Pin 30h on the coil. In the fuse box it is BK/GN and runs to the unloader relays.
Pin 16, WH/BK comes from Pin 6 of diagnostic connector and is used in the SRS system. In the fuse box it is WH/BK and is said to be not used.
Pin 18, BK/YL is the starter trigger and comes from in the car. It is also BK/YL in the fuse box. It also runs to Pin 11 of the diagnostic connector.
Pin 20, RD/YL comes from Pin 87 of the main relay. It is RD/YL and goes to power the ABS Hydraulic Unit.
seems the same but that cant be right as half the colours were different
Post Fri May 04, 2012 10:43 pm
I've found wiring diagram for the E34 ALex, but it's for the M52, not sure if that's going to help. :?
johnl320
Post Fri May 04, 2012 10:49 pm
Have you got a check panel alex?
Post Fri May 04, 2012 10:50 pm
Might be getting somewhere now :D
so i match this upto the e30 plug i'am guessing
johnl320 wrote:Have you got a check panel alex?
Yep :)
johnl320
Post Fri May 04, 2012 10:53 pm
Yes but are they in the same pin location on the e30 loom Alex??
Post Fri May 04, 2012 11:02 pm
surely they will be ?
i'am getting confused if iam honest :o:
Post Fri May 04, 2012 11:03 pm
Good find Alex, looks to be the one.
johnl320
Post Fri May 04, 2012 11:06 pm
All I'm saying is that you can easily identify what wire does what on the engine loom. you just need to lift the rubber boot off the car side of the plug and identify those wires and pin locations are compatible before you commit to connecting them
Post Fri May 04, 2012 11:07 pm
Shame your tooooo far Alex, otherwise I would be lending you a hand on the fooked wiring. :D
Post Fri May 04, 2012 11:24 pm
johnl320 wrote:All I'm saying is that you can easily identify what wire does what on the engine loom. you just need to lift the rubber boot off the car side of the plug and identify those wires and pin locations are compatible before you commit to connecting them
forgive my ignorance :D
but if the c101 connector is off another 325i 1989 more door manual wont it be the same underneith ? :D
Cheers Rav :D i need to get this car on the road for the next York raceway Event :D
leeparkes
Post Sat May 05, 2012 12:02 am
I had one of these late looms when i was having running problems with mine.
I sent Bristol_jer a pm as he'd done the late loom swap and it was running fine, if i remember he wired it colour to colour but some wires were left out (not needed)
Drop him a pm, or search his post.
http://www.e30zone.net/modules.php?name ... le&u=35172
Also remember later C101's have 25 pins whereas early ones have 20. :)
Post Sun May 06, 2012 11:29 am
soldering it all together now and iam finding the wires on the m30 loom to be the same as that of an s38 no wonder iam confused
looking at where the previous connections it was also wired up to m535i colours
Post Sun May 06, 2012 12:35 pm
Thats an X20 Lee
C101 on left, X20 on right
Post Sun May 06, 2012 12:43 pm
ive flowed a couple of diagrams for the pin layouts on the c101 lugs and ive only found 2 wires that are different so ive wired them up like the s38 would be
Post Sun May 06, 2012 12:45 pm
whats an underloader relay ?
Post Sun May 06, 2012 12:47 pm
You need to wire it up as an E30 engine Alex, type out what you have in each pin and I will try and help
Post Sun May 06, 2012 12:56 pm
ive done everthing colour to colour apart from the two oil level sensor wires which ive done as per s38 as there are no matching wires.
Ive cross referenced every pin number from here and the wiki
http://img.photobucket.com/albums/v102/ ... ing1-1.jpg
however i'am left with no abs wire on the m30 loom :S
according to this i think ive done the right thing with the oil level sensor
http://www.mye28.com/viewtopic.php?p=896522
Post Sun May 06, 2012 1:28 pm
i pm'd bristol_jr and it apperars ive wired it all correctly apart from the two oil level sensors (static and dynamic)
here what it looks like ive got some bmw fabric tape and will remove the unused wires.
these are the last bits i need to sort out
Green/black wire for underloaded relay what ever one of them is :o:
and i belive this is the oil level sensor but i'am unsure where this connects to, not sure why it was removed originally :?
