e36 328 sport bbs rims
kingludba
Sat Mar 17, 2012 10:16 pm
will these fit after carrying out a 5 stud conversion or will there be a need to modify arches ? The wheels in question are staggered, not sure what "J" they are.
Gav
Sun Mar 18, 2012 12:14 am
You will ideally want spacers to bring them out if you did the 5 stud conversion using E30 M3 parts, should fit ok if using E36 stuff.
kingludba
Sun Mar 18, 2012 1:50 am
Been doing some research, found some 4 - 5 stud adapters, less hassle than the conversion but is it safe?
http://www.eurowned.net/wheel-adaptors--spacers.html
go to design 3 system, $199.
Sun Mar 18, 2012 2:32 am
Or put wheels that fit your car.
kingludba
Sun Mar 18, 2012 9:20 am
Blitz wrote:Or put wheels that fit your car.
well then, theres always one :D ,
harry_p
Sun Mar 18, 2012 11:05 am
E36 wheels are a suitable offset to work with spacers / adapters.
7.5 and 8.5 x 17 et41.
However I'm not keen on 4x100 to 5x120 adapters as there will always be one hole which overlaps and I've never seen a solution I would be totally happy with.
cheers,
harry
kam325itouring
Mon Apr 30, 2012 10:10 pm
I had e36 328 staggered rims on my tourer with 20mm adapters, i had them for a year and a half with no issues at all. I have a thread on here somewhere. they did look the tits!! Vdub boys been using adapters for years!!
All Car Audio - Approved Alarms - HID Kits - Custom Boot Installs - All jobs considered
leeparkes
Mon Apr 30, 2012 11:16 pm
Can you get these adapters less than 20mm?
Mon Apr 30, 2012 11:25 pm
leeparkes wrote:Can you get these adapters less than 20mm?
18mm are available from the states Lee. :D
Mon Apr 30, 2012 11:29 pm
pm sent 8)
Mon Apr 30, 2012 11:33 pm
Seen this design before Harry?
http://www.r3vlimited.com/board/showthread.php?t=230901
kam325itouring
Tue May 01, 2012 7:50 pm
If your going to run e36 rims et41 20mm adaptors are perfect!
harry_p
Tue May 01, 2012 8:27 pm
nope, not seen those before. certainly the best solution i've seen (other than two stage adapters which are going to be 30mm as a minimum) and would be reasonably happy with them on a road car.
cheers,
harry
