will these fit after carrying out a 5 stud conversion or will there be a need to modify arches ? The wheels in question are staggered, not sure what "J" they are.
Gav
e36 328 sport bbs rims
kingludba
Been doing some research, found some 4 - 5 stud adapters, less hassle than the conversion but is it safe?
http://www.eurowned.net/wheel-adaptors--spacers.html
go to design 3 system, $199.
E36 wheels are a suitable offset to work with spacers / adapters.
7.5 and 8.5 x 17 et41.
However I'm not keen on 4x100 to 5x120 adapters as there will always be one hole which overlaps and I've never seen a solution I would be totally happy with.
cheers,
harry
harry
kam325itouring
- Contact:
I had e36 328 staggered rims on my tourer with 20mm adapters, i had them for a year and a half with no issues at all. I have a thread on here somewhere. they did look the tits!! Vdub boys been using adapters for years!!
All Car Audio - Approved Alarms - HID Kits - Custom Boot Installs - All jobs considered
- E30 Zone Meets/Events Team
- Contact:
18mm are available from the states Lee.leeparkes wrote:Can you get these adapters less than 20mm?
- Contact:
http://www.r3vlimited.com/board/showthread.php?t=230901
kam325itouring
- Contact:
If your going to run e36 rims et41 20mm adaptors are perfect!leeparkes wrote:Can you get these adapters less than 20mm?
nope, not seen those before. certainly the best solution i've seen (other than two stage adapters which are going to be 30mm as a minimum) and would be reasonably happy with them on a road car.Rav335uk wrote:Seen this design before Harry?harry_p wrote:
cheers,
harry
harry
