Gearbox power rating
Hoobs
Post Sat Apr 28, 2012 11:42 pm
How much power can a 325 gearbox cope with safely / regularly?
I have my old 323 box mated to an M52 with an uprated paddle clutch. I also run an e12 LSD.
I'm wondering if the box will be able to cope long term??
Rally Prep - Cornwall
ARM BMW & Motorsport
2002
E30 M3 2.3 - Alpha N, C/F airbox etc
mrLEE30
Post Sun Apr 29, 2012 5:50 am
Getrag 260 can cope with 260N/m the 240 can handle 240.
These are the standard m20/10/40 boxes. M3 had a 265, you can guess the power handling ability of that!!
Hoobs
Post Sun Apr 29, 2012 7:09 am
Every days a school day. :teehee:
Thanks.
2002
Post Sun Apr 29, 2012 11:11 am
the 260 boxes can take way more as can the 265's. 240's wont
e301988325i
Post Sun Apr 29, 2012 11:18 am
Simon13 wrote:the 260 boxes can take way more as can the 265's. 240's wont
I'm sure I read they can reliably long term take +50% of their rating so 390 Nm = 288 lb/ft!
I said:
e30topless said:
lock the wife in there
mrLEE30
Post Sun Apr 29, 2012 4:01 pm
i am sure they can, but that is their rated maximum torque capacity
Post Sun Apr 29, 2012 5:56 pm
mrLEE30 wrote:Getrag 260 can cope with 260N/m the 240 can handle 240.
265 NM = 195.45lbft.
An M30B35 of which a getrag 265 is often mated to is rated at 225lbft which = 305NM.
Andyboy
Alpina Colada
Post Sun Apr 29, 2012 9:44 pm
The 240/260 numbers don't really mean anything. They are just codes for gearboxes. The 265 is merely a five speed version of the four speed 262 and the 245 was somewhat weaker than the 240. Almost all E36 325i's used the Getrag 250 without issue.
randomspeedfreak
Post Mon Apr 30, 2012 10:40 am
what can an is box take?
mrLEE30
Post Mon Apr 30, 2012 1:15 pm
Andyboy wrote:The 240/260 numbers don't really mean anything. They are just codes for gearboxes. The 265 is merely a five speed version of the four speed 262 and the 245 was somewhat weaker than the 240. Almost all E36 325i's used the Getrag 250 without issue.
I was sure that the 240 and 260 were their rated allowable torque, Getrag even today follow the same practice on thier manual gearboxes...
http://www.getrag.com/en/214.1?_search_ ... _offset_=0
but as everyone correctly says they will handle more torque, but it will affect the life of the gearbox.
Steve
Post Mon Apr 30, 2012 1:25 pm
A lot of the turbo boys are making big power with a standard gearbox the issue is normally more to do with the clutch.
webmaster@e30zone.net
e301988325i
Post Mon Apr 30, 2012 8:57 pm
randomspeedfreak wrote:what can an is box take?
Not only having been hand crafted by god himself but also galvanised, I think it could take 150% of it's infinityNm rating.
I said:
ross_jsy
Post Tue May 01, 2012 1:17 am
Steve wrote:A lot of the turbo boys are making big power with a standard gearbox the issue is normally more to do with the clutch.
Was told by the guys on e30 tech that the drive shafts will let go before a 260 normally. Pretty impressive stuff really
