How much power can a 325 gearbox cope with safely / regularly?
I have my old 323 box mated to an M52 with an uprated paddle clutch. I also run an e12 LSD.
I'm wondering if the box will be able to cope long term??
Gearbox power rating
Hoobs
Rally Prep - Cornwall
ARM BMW & Motorsport
2002
E30 M3 2.3 - Alpha N, C/F airbox etc
2002
mrLEE30
Getrag 260 can cope with 260N/m the 240 can handle 240.
These are the standard m20/10/40 boxes. M3 had a 265, you can guess the power handling ability of that!!
Hoobs
Every days a school day.
Thanks.
Thanks.
2002
2002
the 260 boxes can take way more as can the 265's. 240's wont
e301988325i
I'm sure I read they can reliably long term take +50% of their rating so 390 Nm = 288 lb/ft!Simon13 wrote:the 260 boxes can take way more as can the 265's. 240's wont
I said:
e30topless said:
lock the wife in there
mrLEE30
i am sure they can, but that is their rated maximum torque capacity
265 NM = 195.45lbft.mrLEE30 wrote:Getrag 260 can cope with 260N/m the 240 can handle 240.
An M30B35 of which a getrag 265 is often mated to is rated at 225lbft which = 305NM.
Andyboy
- Alpina Colada
The 240/260 numbers don't really mean anything. They are just codes for gearboxes. The 265 is merely a five speed version of the four speed 262 and the 245 was somewhat weaker than the 240. Almost all E36 325i's used the Getrag 250 without issue.
randomspeedfreak
what can an is box take?
mrLEE30
I was sure that the 240 and 260 were their rated allowable torque, Getrag even today follow the same practice on thier manual gearboxes...Andyboy wrote:The 240/260 numbers don't really mean anything. They are just codes for gearboxes. The 265 is merely a five speed version of the four speed 262 and the 245 was somewhat weaker than the 240. Almost all E36 325i's used the Getrag 250 without issue.
http://www.getrag.com/en/214.1?_search_ ... _offset_=0
but as everyone correctly says they will handle more torque, but it will affect the life of the gearbox.
Steve
A lot of the turbo boys are making big power with a standard gearbox the issue is normally more to do with the clutch.
webmaster@e30zone.net
e301988325i
Not only having been hand crafted by god himself but also galvanised, I think it could take 150% of it's infinityNm rating.randomspeedfreak wrote:what can an is box take?
I said:
ross_jsy
Was told by the guys on e30 tech that the drive shafts will let go before a 260 normally. Pretty impressive stuff reallySteve wrote:A lot of the turbo boys are making big power with a standard gearbox the issue is normally more to do with the clutch.
