E30 M52
stu328is
Post Tue Apr 10, 2012 5:14 pm
Just after a bit of advice
I have a e36 328sport as my daily but it's getting to the point where i don't want to spend anymore on it as it has rust issue's and is a cat D, so to me it's not worth spending any more coin on it
My engine is fine so instead of selling the whole car for peanuts was thinking swapping it into the e30, what other parts would i need and how much roughly do you think to have someone do the full swap?
does anyone know who might take this on in east london area?
thanks for any help
Grrrmachine
E30 Zone Wiki / Team Member
Post Tue Apr 10, 2012 5:16 pm
This website has an entire forum dedicated to the M50 and M52, as well as a comprehensive Wiki page:
http://www.e30zone.net/e30zonewiki/index.php/M5x
rich318i
Post Tue Apr 10, 2012 5:23 pm
stu328is wrote:Just after a bit of advice
thanks for any help
it all comes to about 1200-1300 fitting and the bits give this garage a call they did mine and they are in se london : 0207 635 6792 A.M.W
stu328is
Post Tue Apr 10, 2012 5:24 pm
Nice one, will have a read
stu328is
Post Tue Apr 10, 2012 6:58 pm
thanks for any help
Sorry missed this some how, cheers
rich318i
Post Tue Apr 10, 2012 7:10 pm
thanks for any help
they have done many coversions and know what they r doing. ask for andy
sunnyr83
Post Tue Apr 10, 2012 7:28 pm
What's the other e30 you have??
I was planning this but found it so hard to find a decent shell to get started. 1 day.
stu328is
Post Tue Apr 10, 2012 7:57 pm
Just got the one e30, the e36 is in the background
rich318i
Post Tue Apr 10, 2012 8:14 pm
stu328is wrote:Just got the one e30, the e36 is in the background
like button hit! what engine is in the e30?
stu328is
Post Wed Apr 11, 2012 6:42 am
It's a 2.5, still not sure what to do really as the the engine is only on 94k
sunnyr83
Post Wed Apr 11, 2012 7:40 pm
I'd say get it done, your nearly there. Get the other bits of Danthe. Have a look at the different options.
I was going down the route of Bhups conversion
M52 and gearbox and prop
Danthe wiring loom, rack, manifold
Lightened flywheel
Brake set up of a 2.5
And couple other bit can't remember. As I said finding one was not happning!
I'd say go for it man, but get it done right once!
BATTS91
Post Wed Apr 11, 2012 8:37 pm
if your. ot handy with wires danthe loom and ews delete ,danthe manis , clio servo an some mounts , use 328 box pull like a train top out at about 130-140mph ,rack is not essential me and will have e30 racks no need to mod pipes as some sayif stayin standard , but as people say its a good conversion your choice ,and sort an electric or viscous most likely will need lecy if using rubber engine mounts danthe does looms for these too if electrics are a problem basically all you need to pay for to get it in and running is danthe bits and a servo which is easy to do btw
youll defo feel te diffrence from your m20 ,
i have m50 2.5 vw-will has m52 2.8 n you can feel and see the diffrence from a rolling start in 2nd he made a good 3 car lenghs on me
stu328is
Post Thu Apr 12, 2012 9:48 am
Decisions decisions, it was Bhups one that got me thinking about doing it tbh
I'd have to get someone to do it for me as i haven't got the time to do it myself and couldn't be without a car for too long.
Don't get me wrong the m20 goes well enough but i imagine it will go really well with the M52 in it, the 36 feels a fair bit quicker and that's a tank compared to the e30 and why would it only do 130-140 in the e30 with the 28 box? the 36 is heavier and it pulls to an indicated 150 fairly easy, i wouldn't have though the brick shape aero of the e30 would hold it back that much
Post Thu Apr 12, 2012 10:11 am
stu328is wrote: and why would it only do 130-140 in the e30 with the 28 box? the 36 is heavier and it pulls to an indicated 150 fairly easy, i wouldn't have though the brick shape aero of the e30 would hold it back that much
This is probably using an E36 direct top gear box in plae of the E30 overdrive gearbox, without changing the diff ratio to suit.
Gives you a car with an extra sub first gear and fourth as a top gear.
stu328is
Post Thu Apr 12, 2012 10:45 am
Ah right, i'd change the diff anyway as it's a bit whiney so may as well find an LSD to suit
BATTS91
Post Thu Apr 12, 2012 11:05 am
explained above its due to the 1:1 final drive , well i presume your standard diff is a 3.64 with that uoud be looking at 130-140 , but seriously do u need more than that , its going to have uber acceleration from using 3.64 ,but if you must then i think its a 2.93 or 2.65 "i think there right" but that will just be boring slow if you ask me
Post Thu Apr 12, 2012 1:35 pm
It will not have 'uber acceleration' with an E36 box and an E30 diff. First gear will be useless (the gain will be negated by the time it takes to change gear) and you will effectively have a four speed gearbox.
My first M50 conversion initially had a 4.1 diff, which was great fun, lighting up the tyres at will in the lower gears, but the stop watch proved it was slow.
A 3.64 on an E30 gearbox translates to a 2.95 on an E36 box.
3.15 torsen LSD from a Z3 2.8 is an ideal choice, slots straight into an E30, and doesn't have clutch plates which wear out after about four hours of use.
BATTS91
Post Thu Apr 12, 2012 2:21 pm
how many of those diff do you cone across tho ,thats the thing everything you do depends on you budget get sorted on that then decide i rekon
Post Thu Apr 12, 2012 6:31 pm
BATTS91 wrote:how many of those diff do you cone across tho ,thats the thing everything you do depends on you budget get sorted on that then decide i rekon
Paid £80 for mine - for the complete rear subframe, although it was a little bent!
Dezzy
CR24v it's a lifestyle
Post Thu Apr 12, 2012 6:41 pm
There's the cost of welding it up on top of that to consider into the budget Brian. :roll:
BATTS91
Post Thu Apr 12, 2012 6:50 pm
bargain really i spose cnt find anythin lower than a 3.64 for less than £100 , i was using a 4.1 that was awfull ,1st gear non existant the 3.64 came up or £30 spot on
nickso
Post Thu Apr 12, 2012 7:04 pm
MIne uses a e36 box and 3.15 diff and is anything but boring slow.
'88 e30 328i M52 track bint.
Dezzy
Post Thu Apr 12, 2012 7:37 pm
My M52B30 is using a E36 M50B25 box with 3.15 diff.
Its perfect IMO.
Through the box its spot on. The only issue I have is it is just coming on song at 80mph in 5th.
Its too easy to have it off the clock :roll:
stu328is
Post Fri Apr 13, 2012 7:16 pm
Cheers for all the advice chaps, I better get saving for the bits
Stu
E36 328 Sport
E30 325i
Mk2 Golf 8v
