whats the best way to extract 2 broken exh, studs 0ut a 325i
e30geezer
Post Sat Nov 26, 2005 4:02 pm
hello guys 2 studs are snapped by previous owner, whats the easiest method to get them out , and to ensure i dont snap the others, ive heard there is a trick to do this any help would be gratefull thanks , its a 1990 325ise . [/img]
jonbuoy
Post Sat Nov 26, 2005 4:19 pm
Firstly, take the Manifold off and change all of the stud's so there are no problem's in the future.
Secondly, oxi & ceterlin(sp) if the stud is pertrooding(sp)
or if they are'nt pertrooding then you'll have to drill them out mate.
Good luck
exup
Boost Junkie
Post Sat Nov 26, 2005 4:38 pm
if u got a welder , grind old bolt shank down to a point and weld it on to broken one then when cool , undo easyer than drilling right out :)
e30geezer
Post Sat Nov 26, 2005 5:14 pm
exup wrote:if u got a welder , grind old bolt shank down to a point and weld it on to broken one then when cool , undo easyer than drilling right out :)
cheers mate ,will try this
e30geezer
Post Sat Nov 26, 2005 5:15 pm
jonbuoy wrote:Firstly, take the Manifold off and change all of the stud's so there are no problem's in the future.
Good luck
thanks mate , i gotta get em out somehow and replace the manifold gaskets.
Post Sat Nov 26, 2005 5:29 pm
this is a head off job really as the only room to drill out in situ is the one at the top right at the front!
Kack job!
e30geezer
Post Sat Nov 26, 2005 9:42 pm
Simon13 wrote:this is a head off job really as the only room to drill out in situ is the one at the top right at the front!
Kack job!
hi, simon yep the 2 fronts have gone any idea how much i should be looking to pay. cheers ( rob )
PeteE30Tourer
Post Sat Nov 26, 2005 10:12 pm
Sounds like a Tech Help query to me.
Please post in the appropriate forums.
Back behind an M20, but now I can hear it better.
fixedwheelnut
Post Sun Nov 27, 2005 1:27 am
If you can get hold of a right angled drill and use a left handed drill bit, "I'm not takin the p**s Snap-On do them" that way as you drill it the force is undoing the stud not tightening it, if that fails try the weld a bolt head on as the heat transfer also helps to loosen the stud.
TouringMatt
Post Sun Nov 27, 2005 11:06 am
Got this problem myself, gonna try the weld method first.
But just a thought, instead of welding a washer etc to the broken stud to remove it, ( is this always 100% effective ) could you weld a smalled threaded stud on and just use that to bolt the manifold on??
How much are studs torqued up?
Matt
Widge
Post Sun Nov 27, 2005 12:21 pm
I had two snapped at the front and two at the back, so I had to sort it out really. I took the car with no manifold on!!!!!! down to the local agricultral engineers who fix all our tractors, the guy got two out with Oxy Acetelene and a nut as they were protruding. The other two he got out by drilling and then using the torch and a stud extractor, the rear one he couldn't drill straight so he drilled it a size bigger (M10?? or was it M8) and put a larger stud in and drilled my manifold to suit. Cost Ԛ£50 in total I think, bargin.
Post Sun Nov 27, 2005 3:40 pm
Good luck
Take the greatest care not to shear any more when you remove the manifold. Split or grind the nuts off if neccessary.
When you reassemble, copper grease is your friend.
e30geezer
Post Sun Nov 27, 2005 10:00 pm
Good luck
thans mate good tips there.
