The e36, e30 or the e21??
DanThe wrote:If your using an M20 fly, an M20 clutch, then you should be using an M20 release bearing
slave does match the gearbox m52 ZFblue30 wrote:Slave needs to match the gearbox, slave should have the mount ears 1/2 way down it not at the front like e30 ones.
When I swapped from m40 box to ZF box I only had the M20 slave and had the same problem as you, the rod just popped out, nearly lost it in the bellhousingrich318i wrote:slave does match the gearbox m52 ZFblue30 wrote:Slave needs to match the gearbox, slave should have the mount ears 1/2 way down it not at the front like e30 ones.
Does yours look the same as this....rich318i wrote:been having a problem with my m20 conversion. is the m20 bearing too short for 328i gearbox? put a new slave on a m52 one and it pushes the pin out too far and pops it out of the slave, but it still drives and slips abit
the ball at the end of the pin is not the same as mine, but think its sorted now fingers crossed
