need to take a big hammer to the car
Seems when I fix one problem theres another with my e30, no come to take back wheels off and seem to be stuck solid, I did have a tyre changed and the guy used like a over sized rubber mallet, but asked everyone I know and no luck, really need wheels off todo work, any ideas? Im in the aldridge area if anyone is close? And would like to help me
thanks
- rover-2000
Aldridge-as in near Walsall? If so, I'm near the Longhorn pub on Sutton Road-free on Sunday if you want to call round?
Kind regards
John
1989 320i Touring
1993 E34 525i SE Touring
1979 Porsche 924 Lux
1982 Porsche 924 Lux
1985 Porsche 944 Lux
John
1989 320i Touring
this may work , crack bolts off half way sit on the ground with a foot on either side of the tyre and kick left rifht left right should free it some if not take bolts out fully , once off get yourself a wire brush hope this helps
get under the car, with all the wheel bolts of, get a block of wood and sizable hammer. place the wood on the rim and hit accordingly, spin it after every hit aswell
do this day in day out of merc shitters lol
make sure you clean all the shit of after and copper slip the fook out of it
When I couldn't get the rears off the manta I undid the bolts a few turns and drove round the block! Did the trick
Guys I done it now well happy
just narks me sometimes that I can do hard task, and something simple i.e wheels and struggle grr... Just a question with all this hitting with a lump hammer inside the rim, could I of damaged bearings etc?? Thanks guys just some-times its the support off here keeps me going.
mucka88 wrote
He hit the back of the wheel with a lump hammer?!
BATTS91 wroteGuys I done it now well happy just narks me sometimes that I can do hard task, and something simple i.e wheels and struggle grr... Just a question with all this hitting with a lump hammer inside the rim, could I of damaged bearings etc?? Thanks guys just some-times its the support off here keeps me going.
I reckon, this is a stab in the dark mind...in regards to bearings id say not really they should be perfectly fine just hope you didnt damage your wheel
how did you get it off then sir ?
Well BATTS91 I was pulling your leg.BATTS91 wrote:well dezzy he said he tryed hitting it first before trying my method all in all its off , good to hear you have your steering done
It is indeed now off and he did get the idea off you. He gave it a few BATTS.
