need to take a big hammer to the car
mucka88
Fri Mar 30, 2012 6:46 pm
Seems when I fix one problem theres another with my e30, no come to take back wheels off and seem to be stuck solid, I did have a tyre changed and the guy used like a over sized rubber mallet, but asked everyone I know and no luck, really need wheels off todo work, any ideas? Im in the aldridge area if anyone is close? And would like to help me :) thanks
rover-2000
Fri Mar 30, 2012 6:49 pm
Aldridge-as in near Walsall? If so, I'm near the Longhorn pub on Sutton Road-free on Sunday if you want to call round?
Kind regards
John
1989 320i Touring
1993 E34 525i SE Touring
1979 Porsche 924 Lux
1982 Porsche 924 Lux
1985 Porsche 944 Lux
mucka88
Fri Mar 30, 2012 7:23 pm
Yes thats it mate, cant drive my car at the moment as got to replace steering rack on it soon as I get time haha, thanks ;)
BATTS91
Fri Mar 30, 2012 7:26 pm
this may work , crack bolts off half way sit on the ground with a foot on either side of the tyre and kick left rifht left right should free it some if not take bolts out fully , once off get yourself a wire brush hope this helps
chaz_316
Fri Mar 30, 2012 7:27 pm
get under the car, with all the wheel bolts of, get a block of wood and sizable hammer. place the wood on the rim and hit accordingly, spin it after every hit aswell :)
do this day in day out of merc shitters lol
make sure you clean all the shit of after and copper slip the fook out of it :)
mucka88
Fri Mar 30, 2012 7:37 pm
Tryed the would and lump hammer no good, I gonna try batts way now, back out in the cold haha
BATTS91
Fri Mar 30, 2012 7:42 pm
dont be afraid to kick hard bud and keep ya feet flat on the ttee if you can :)
Green
Fri Mar 30, 2012 7:54 pm
When I got my E30 I couldn't even crack the bolts a quarter turn easily, then after removing the bolts it was a pain in the backside removing the wheel itself! Just gave it a good kicking in the end.
Tom_Maverick
Fri Mar 30, 2012 8:12 pm
When I couldn't get the rears off the manta I undid the bolts a few turns and drove round the block! Did the trick :)
Green
Fri Mar 30, 2012 8:25 pm
Tom_Maverick wrote:When I couldn't get the rears off the manta I undid the bolts a few turns and drove round the block! Did the trick :)
Top quality top tip... 8O
mucka88
Fri Mar 30, 2012 8:35 pm
Guys I done it now well happy :D just narks me sometimes that I can do hard task, and something simple i.e wheels and struggle grr... Just a question with all this hitting with a lump hammer inside the rim, could I of damaged bearings etc?? Thanks guys just some-times its the support off here keeps me going.
BATTS91
Fri Mar 30, 2012 10:44 pm
in regards to bearings id say not really they should be perfectly fine just hope you didnt damage your wheel
how did you get it off then sir ?
Dezzy
CR24v it's a lifestyle
Fri Mar 30, 2012 11:01 pm
mucka88 wrote
Guys I done it now well happy just narks me sometimes that I can do hard task, and something simple i.e wheels and struggle grr... Just a question with all this hitting with a lump hammer inside the rim, could I of damaged bearings etc?? Thanks guys just some-times its the support off here keeps me going.
I reckon, this is a stab in the dark mind...
He hit the back of the wheel with a lump hammer?! :mad:
adit
Fri Mar 30, 2012 11:04 pm
:chuckle:
[quote="bss325i"]
mucka88
Sat Mar 31, 2012 5:56 pm
Done the power rack now, next to clean up the wheels
BATTS91
Sat Mar 31, 2012 6:13 pm
my bad dezzy i thought he tryed hitting with hammer before my method all in all good job its off and your rack is done top stuff
Dezzy
BATTS91 wrote:well dezzy he said he tryed hitting it first before trying my method all in all its off , good to hear you have your steering done
Well BATTS91 I was pulling your leg.
It is indeed now off and he did get the idea off you. He gave it a few BATTS. :o:
Sat Mar 31, 2012 6:38 pm
size 9's work well .
Dezzy
Sat Mar 31, 2012 6:45 pm
magpie wrote:size 9's work well .
I normally just bang them off with my c0ck. winkeye
