Sticking rev counter
Beemer325
Post Wed Feb 16, 2005 9:47 am
The rev counter has suddenly started to stick. Evertime I start the it either doesn't budge at all or the needle sticks at the 2000 rpm mark. It then eratically shoots arounds the rev counter and only once the car is warm will then calm down and work properly. :mad:
Would this have anything to do with the cold weather we have been experiencing lately or is there something more sinister going on that I need to look at?
al325i
Post Wed Feb 16, 2005 11:06 am
Hi There
Mine is stuck at 3000rpm and rarely moves. had it checked out and it is the rev counter unit that is faulty. You need to get hold of either a rev counter or a full set of clocks and swap the rev counter over into your clocks.
Obviously you need to make sure the rev counter you are going to fit is not F****d 8)
Al
Beemer325
Post Wed Feb 16, 2005 11:28 am
Is there any reason why the rev counter would just stop working all of a suddenly?
Guest
Post Wed Feb 16, 2005 12:13 pm
Ive also heard that sometimes the gauges can do strange and unusual things due to dead service board batteries. There is a small circuit board within your instrument cluster which controls when your service indicator lights come on amongst other things. This board has two AA NiCad batteries soldered to it which when your ignition is switched off, supply power to maintain the memory of your service indictaor lights. I have read that when these batteries eventually fail, the instrument gauges and lights can malfunction. This may be another cause for you to investigate...
Post Wed Feb 16, 2005 1:19 pm
Rev counter should be unaffected tho i think
Cheaper to try a new rev counter module than a new SI board to start with!
Beemer325
Post Wed Feb 16, 2005 2:38 pm
Jhonno wrote:Rev counter should be unaffected tho i think
Where would I find the rev counter module Jhonno?
android
Post Wed Feb 16, 2005 8:33 pm
I had a similar problem to this, and fixed it with a second hand SI board bought off this site. They come up occasionally.
My temp gauge was also sticking
Post Tue Feb 22, 2005 11:08 pm
Rev counter can definitely be affected by a duff SI board, but a sticking rev counter can be caused by dirt or damage on the gears which drive the needle.
