flood mode?
otterstricks
Post Thu Mar 22, 2012 10:11 pm
Hi folks, I'm planning on doing a compression test on my 3.18i witht the M40 engine and I'm wondering if these units have a flood mode? i.e if I have the accelerator right down on turning the key will it suspend fuel being sent to the injectors? It would make the process of testing much quicker as I don't want to send unused fuel down to the catalytic convertor.
Cheers fellas
Murdo
parkin10
Post Thu Mar 22, 2012 10:37 pm
just pull the fuel pump relay out
Post Thu Mar 22, 2012 10:46 pm
there's no real need to do anything but remove all 4 plugs before the test, fuel will be minimal
Post Thu Mar 22, 2012 11:28 pm
If you use the pins in the diagnostic socket, kindly placed there by BMW for the purpose, to crank the engine over, instead of the key, no fuel will be injected, the fuel pump won't run, and there will be no risk of an HT flashover damaging the ECU as a result of plug leads being left unloaded.
otterstricks
Post Fri Mar 23, 2012 12:16 pm
Hi Brian, what pins should I use and is it just a case of bridging the 2 connectors?
Post Fri Mar 23, 2012 1:44 pm
Bridge 11 and 14
Morat
Post Fri Mar 23, 2012 2:43 pm
I'm curious about this, because the other day I stalled and tried to restart immediately but only gave it a half hearted stab at the key before my finger slipped off. No go. I cranked again and nothing after 10s. I left it 10s and cranked with my full fully down on the throttle and she started up after about 5s of cranking. Hasn't missed a beat since.
