The drivers side, however, leaves a little to be desired!!!
The lock lever feels a touch loose and it locks in to place too easily!!
It would never come open and doesn't really cause much of an issue tbh, but it does have a bit of play, which means a bit of extra wind noise (I can pull the roof down and reduce the wind noise!!) and the occasional leaky drip when it's been raining heavily (although normally just when changing cambers on and off the driveway, etc!!!).
It looks to me that there should be slightly more of a 'nipple' on the body (above the windscreen) where the lock clicks into place.
Any ideas what I can do to improve/rectify this??
Would changing the lock handle for a more solid one be worth a try?? Or should I try and improve the nipple somehow???
Also, the drivers dool seal keeps pinging off and is really irritating me!!!
It looks to be in good condition, fits fine when encouraged back on and is water tight, so should i just try and re-fix it with a dab of sealant of some kind???
Will an expensive new seal really stay in place any better???
All ideas welcom on that one too!!!!
Thanks in advance!!!
