witch clutch cylinder?
hi all, i have a cluch problem, ive posted somthing about it before but cant find the thread, breifly... in the morning when i start the car i cant select a gear without banging it in, and the bite is realllly low, so low that when stationary with my foot all the way down standing on the cluch, if i take my foot off the brake the car will move, which cylinder would cause this to happen, it feels a little slack aswell, not as hard as my other car was, thanks
fuzzy
assuming the fluid isnt leaking or low have you tried bleeding the system?
320
well i had a rear brake cylinder leak which i have now sorted, i have bled that brake, iv had really weak brakes for a little while also with the cluch problem. i was loosing fluid before changing the brake cylinder, how do i bleed the clutch?
fuzzy
theres a bleed nipple on the clutch slave cylinder if i remember correct.
macas
On the side of the gear box tom,
320
throw a pic up, i can give it a whirl on my dinner break tommorow
320
right, we bled the slave cylinder this evening and all that came out was old black stuff, i have put fresh fluid in when i changed the brake cylinder so shouldnt be black, and nothing else comes out, there doesnt seem to be any fluid getting through to the slave cylinder, is the slave fooked?, theres no leak from it. the cylinder under the pedal seems ok, it doesnt get stuck or just flop, it doesnt have any pressure but the pedal still comes back up, i now have no clutch, any advice plz? thanks
It will be black because the master is fooked, you need new master and slave cylinders to sort your problem reliably
320
there was pressure in the pedal before bleeding the cylinder, but the bite was just low, but as soon as we started bleeding the cylinder the pressure just went and hasnt come back,
Thats because the seals have gone, hence the black, rubber contaminated fluid
320
itll be over a hundred quid to change both, it would be better if i could do 1 this week and do the other next, which 1 would you say needs changing with the info i have given?
Both,,, it wont be over £100, £50-£60 tops, use the zone ECP contact for trade discount
And get a braided clutch hose from Ebay whilst you're at it to replace the rubber almost-certainly-fooked one that is currently there.
320
how do i go about using the zone ecp contact? thanks
320
capri_rob wrote:And get a braided clutch hose from Ebay whilst you're at it to replace the rubber almost-certainly-fooked one that is currently there.
to be honest i wana keep costs down as i dont know if im gonna keep it yet, it was in a accident a little while ago and hs been written off, not bad damage but dont wanna spend too much on it, i only paid 300 quid for it.
