Service parts.
kolee
Post Tue Mar 13, 2012 9:02 pm
I know thie answer is on the forum somewhere, but the search function throws up 20 million results without an actual result.
I'm usually a lazy facker and let a friend do all the work on my car (I'm a girly office type- and i might break a nail!), but i'm determined to start getting my hands dirty.
Got some plans to start some body work this weekend, but thought i could chuck in some new service parts at the same time.
All i want is recommendations for the best parts to use, and where to order them from. I have scoured ebay, Halfords, ECP and a few other places and there is way too much choice for an indecisive sod like me to pick the right one.
Air Filter
Fuel Filter
Oil filter
Spark Plugs
Post Tue Mar 13, 2012 9:05 pm
Oil filter genuine from dealer about £10, or Bosch from ECP for under a fiver
NGK Plugs from ECP
Bosch fuel filter from ECP
Air filter from ECP
Order online, use "Service25" as the discount code for 25% off - or see if meatballs82 ( Matt ) can sort you out with better prices
kolee
Post Tue Mar 13, 2012 9:07 pm
Perfect, thanks capri_rob.
PS. this sort of info should be in the wiki or simply stickied in tech section!
Grrrmachine
E30 Zone Wiki / Team Member
Post Tue Mar 13, 2012 9:17 pm
Engine Oil - 10w/40 Semi Synthetic
Gearbox (Manual or Auto) Oil - Castrol Dexron III ATF
Power Steering Fluid - Castrol Dexron III ATF
Brake Fluid - Dot 4
Clutch Fluid - Dot 4
Open Diff - Bmw OSP 75w-90
LSD- Bmw MSPA 75w-140
Spark Plugs - NGK BPR6ES
Air filter - Mann M20 filter
Fuel filter - Mann M20 fuel filter
Oil Filter - Original BMW filter
Timing Belt - Original BMW
Tensioner & water pump - Euro car parts or German & swedish
Coolant- BMW
Maybe if you told us the car, I could be more specific...
kolee
Post Tue Mar 13, 2012 9:24 pm
Crap, i do rush sometimes when writing.
'86 325i se chromie manual.
redcar
Post Tue Mar 13, 2012 9:28 pm
ATF in the gearbox? :?
Grrrmachine
Post Tue Mar 13, 2012 9:33 pm
kolee
Post Tue Mar 13, 2012 9:39 pm
Thanks very much.
E30_Crazy
Post Wed Mar 14, 2012 12:47 am
redcar wrote:ATF in the gearbox? :?
Same here, I seem to remember doing some reading on it, and recall that Dexron ATF is not good for the manuals.
Grrrmachine
Post Wed Mar 14, 2012 5:57 am
If people can suggest a better alternative to anything in that list, I'll amend it and stick it in the Wiki.
Post Wed Mar 14, 2012 6:46 am
You don't need a genuine BMW cambelt - Contitech make them for BMW - buy the Contitech kit from ECP :wink:
