I have a set of wheel that need doing,
Can anyone advise anyone decent? and what kind of cost to expect?
powder coating down south.
turk
S54, S62, S65 & S85 Plug & Play loom/Ecu Kits
Sump Baffles
Engine Conversion Kits/Parts
TrackDays
Sump Baffles
TrackDays
Dezzy
- CR24v it's a lifestyle
Polsta has had some wheels powdercoated and posted the results on here.
He's down your way isn't he?
ah
I used these guys in 2008-9 and did a superb job £50 a corner +£5 for metal part of centre cap.
http://www.wheelrefurbishing.com/
Born on the 23 April 1990 320i Alpinweiss ll kabriolett! (SOLD BUT NOT FORGOTTEN !)
Razorsharp
If you can't get hold of Polsta (don't think he's on here much at the moment) give Vernon a try at the Wheel Specialist in Segensworth : http://www.thewheelspecialist.co.uk/loc ... ham-hants/
He did the wheels on my E63 and the finish was superb. I think it cost about £75 a wheel as they were 19's and pretty wrecked.
powelly
Funnily enough I was enquiring about this yesterday. We use a powder coating company in Curridge near Newbury called Pro Coat, £40 a wheel and the finish is spot on, any colour you like, when I get back from Germany my BBS are going in for a refurb, they really only do the wheels and stuff as a side line as most of their work is high end architectural. Process includes shot blast, degreasing, etch prime then powder coat is the last stage.
Le Mans Classic 2006-
suchy
- True Zone Relic
I can vouch for Vernon also, he does proper high-end stuff and does a VERY good job
aj_mckay
K&N Finishers in Portchester / Port Solent. I've had a couple of sets of wheels blasted and powder coated there and they've been very good both times. Charge is £120-150 per set of 4 depending on wheel size and finish required.
http://www.kandnalloywheels.co.uk/ 02392 370591
EDIT: These are the wheels they've done for me as an example...
