Henna Red M3 Restoration, almost done !
- fourmotion
Looks damn good fella! Are you going to Dastek it with the carbon airbox? (when ready)
Alpha N ,fourmotion wrote:Looks damn good fella! Are you going to Dastek it with the carbon airbox? (when ready)
I intend on running it with the stock M3 stuff for a few k,
or at least until the S14 has settled in,
Looking good Steve.
Can i ask how much the bulkhead insulation cost, the main central bit and battery tray. Also did you just glue them inplace or did you add any rust protection.
Dave, the battery tray is about £28 the centre is £75 or there abouts..
I used no glue just a dose of "hot" waxoil on the upper area, the whole thing is held in place with the Servo and the Large plastic nuts as per factory
I think they had a bit of glue on these in the factory I didn't feel as though it needed it ,
Thanks Steve, bit more expensive than i was hoping but needs must. Will go for a new ally heatsheild as well since the inside was crumbling up.
That's how i was planning on refitting mine but when i saw how well glued it was i wasn't sure just the nuts and servo would hold it well enough without it getting baggy. Will go ahead with the Waxoyl then
Demlotcrew
Not sure i would use waxoil, its going to melt and run with the temps seen under the hood, some light oil would be sufficient to keep it from rusting.
Andrew
Andrew
Demlotcrew
Let's hope so!
I thought the M3 was your boss's or something?e30topless wrote:Alpha N ,fourmotion wrote:Looks damn good fella! Are you going to Dastek it with the carbon airbox? (when ready)
Is it yours now?
i don't have a Boss unless you count the wife Bazzle,
and no, it's not mine I wouldn't own a four pot shitter !
Andrew by the time this is finished the waxoil will have long since dried out !
so after nearly 2 years of sitting on the ramp...
and a spare week or 2 from work I thought I had better get it done
check out the layer of dust !
new screen fitted, Pilkington glass top tinted surprisingly cheap at £145 fitted?
wipers are now RHD after lots of messing around.. a set of new Conti's and all the fiddly bits done,
the turd now has a full MOT
I just need to order another Bumper tape after the other one folded up on me
and fit the M/// badge innit,
chucked a bucket of water over it,
thank f**k that's almost done now I can concentrate on another car
A certain boat anchored Alpina by any chance?e30topless wrote: thank f**k that's almost done now I can concentrate on another car
Topblag
A boat anchored HartgeKedge wrote:A certain boat anchored Alpina by any chance?e30topless wrote: thank f**k that's almost done now I can concentrate on another car
1984 Hartge H35 in Black
2006 Audi S6 V10 in Black 58k
You'll be needing a biggerTopblag wrote:A boat anchored HartgeKedge wrote:A certain boat anchored Alpina by any chance?e30topless wrote: thank f**k that's almost done now I can concentrate on another car
Nice!
