Diff??
baybee
Post Fri Mar 02, 2012 10:36 am
I have recently swapped out my 4.10 open diff for a 3.73 LSD dif. Now when I lock the whell and apply any sort acceleration (normal u-turn) I can hear grinding rough sound coming from the back. Even when im not locking the wheel this sometimes happens as long as i got drive going to the wheels and turning. When i dip the clutch or straighten the wheel, all is well. Are these signs of a faulty diff?
ross2009
Post Fri Mar 02, 2012 2:41 pm
Sounds like the clutches are knackered in the diff
Turbo M20
v8 project 6.0 twin turbo
BenHar
Post Fri Mar 02, 2012 4:31 pm
ross2009 wrote:Sounds like the clutches are knackered in the diff
Unless the grinding sound is the inside tyre slipping, which would show that the diff is working.
Ben
Post Fri Mar 02, 2012 8:34 pm
If you're lucky it just has the wrong oil in it.
