VEMS Group buy 2012 - 640quid shipped in the UK
Traders Section
Gunni
Post Mon Feb 06, 2012 9:24 pm
So I have decided to put together a group buy for VEMS
This is by FAR the best ever deal for a standalone ecu in terms bang for the buck.
This entails the following
1x VEMS ecu with 1x EGT input, 1x 36pin connector and pins, 1x 18pin connector and pins, 1x Bosch wideband sensor and wiring, 1x air temp sensor, 1 x EGT sensor
The ecu comes with a 300kpa map sensor good for 1.8bar boost. This makes the ecu as a whole perfect for any tuning on
M10, M20, M30, M42, M40, M50, M52, M54, S50B30,
S50B32 (more work needed for this one to enable double vanos)
If you have a NA engine this is the ideal solution just as for a supercharged or turbocharged engine.
This group buy ends 11th of March. All payments must be in by 10th.
For this group buy to work at the price I´ve quated we need at least 7 participants.
Here you can get the latest version of Vemstune
http://www.vems.hu/download/VemsTune/NI ... -01-30.exe
Here is a base map you can play with
http://www.vems.hu/files/M50Turbo/Baseline.vemscfg
Here are some instructional videos for the software
In the pics below you can see how I have tailored VEMStune to suit my tuning needs.
For more information about support for VEMS you can visit the http://www.vemssupport.com/forum
I have personally run a VEMS on loads of M20 turbos, M50 turbo, S50B32 turbo, S50B30 turbo, M30 Turbo, 2JZ-GTE in a Lexus, 2JZ in a Supra, Zetecs, RB25, SR20, RB26 and the list goes on ..
The ecu does not require any cost to enable any features.
Such as
Launch control
Boost by speed/Gear
Flatshifting
Antilag (If you rally)
Alpha-N or MAP sensor based
All of the safety features
Wheel speed input
What you DO NOT NEED TO BUY ALSO like with some ecu´s
Ignition amplifier/s (cirka 70quid)
Wideband controller (easily 150quid)
EGT amplifier (40quid I´d guess)
With great challenges comes great engineering.
Gunni
@ 2012 VEMS group buy !!
Ant
Retired Team Member
Retired Team Member
Post Tue Feb 07, 2012 12:02 pm
Bargain People !!!!
Well done for sorting this out Gunni :D
craigieeb
Post Wed Feb 08, 2012 12:59 am
You know im in for one if these gunni mate.
dot
Post Wed Feb 08, 2012 9:44 am
Thanks for the heads up on this thread gunni you can count me in on this, Do you want payment now or when you have the 7 buyers?
Gunni
Post Thu Feb 09, 2012 10:34 am
Payment as soon as possible so that I can display the amount of buyers in this thread. PM for details.
Gunni
Post Thu Feb 09, 2012 1:19 pm
What is the regular price on this?
Can it be taken anywhere for mapping or mainly DIY? Any base maps available?
How would you say it compared to say Emerald/Omex/MBE setups (obviously price comparable)?
Gunni
Post Thu Feb 09, 2012 6:36 pm
Usually this would be in the order of 750.
It can be taken anywhere and a base map always comes with it.
How it compares to other systems comes down to the ability of your tuner. It has no less features then the other ones.
Gunni
Gunni
Post Thu Feb 09, 2012 6:42 pm
I have a customer on another forum who is in.
1. External customer
Gunni
craigieeb
Post Thu Feb 09, 2012 7:02 pm
2. Craig
3. Dot
4.
5.
6.
7.
Ant
Retired Team Member
Retired Team Member
Post Fri Feb 10, 2012 7:15 pm
VEMS is about as good as an ECU setup gets this side of £1500+ the issue was always the software, now finally sorted
MBE is not really suitable IMHO.....
Gunni
Post Fri Feb 17, 2012 12:09 am
2. Craig
3. Dot
4. Another External customer
5. Sag
6.
7.
Gunni
tomislav
Post Mon Feb 20, 2012 5:06 pm
So you either get handy with a laptop and map this yourself or load the base map then drive to someone like ant to map it?
Is that roughly right?
I'm just scared by this sort of stuff but should probably not be!
Gunni
Post Mon Feb 20, 2012 9:44 pm
2. Craig
3. Dot
5. Sag
6. Kris
7.
You load the base map and only minor adjustments will make it run. Or you take it to somebody to map, anybody.
I will have a VEMS reply thread where I give support directly to anybody who´s bought a VEMS.
Gunni
Andeep
Post Wed Feb 22, 2012 11:41 am
Am defo interested, I have sent you a PM Gunni asking about M50 RHD Turbo Manifold
dot
Post Wed Feb 22, 2012 8:04 pm
This might be a stupid question! Does this vems Ecu work with the original BMW Ecu or replace it completely ? I was looking at the installation instructions on the vems website and was confused by one of the earth wiring diagrams as it has manufacturer ecu earth wires, any help would be smashing
Gunni
Post Wed Feb 22, 2012 9:44 pm
It will totally replace the original ecu. Expect better drivability overall.
Gunni
Gunni
Post Fri Feb 24, 2012 12:15 am
So I was just testing the launch control feature.
Depending on what people want it can also be used as a traction control feature with independent traction allowance between gears.
N2O feature works easy enough
It´s possible work around some things and create a water injection feature dependent on TPS, Boost and clt and or air temp.
All kinds of ways to make good use of the ecu apart from making it run your engine better then your motronic EVER could.
Gunni
Gunni
Post Fri Feb 24, 2012 9:09 pm
2. Craig
3. Dot
4. Steve - M50 Turbo non vanos
5. Sag
6. Kris
7.
Gunni
badassyas
Post Fri Feb 24, 2012 9:40 pm
2. Craig
3. Dot
5. Sag
6. Kris
7. Badassyas/BlackE30Indy
Gunni
Post Sat Feb 25, 2012 10:04 am
So everything is officially set for the group buy to go along as we have 7 people ecu´s now.
I have basemaps for
M42,M50,M30, M20,S50B30, S50B32 and very soon M60. As well a whole bunch of other non BMW engines(SR20, RB25, RB26, CA18,2JZ...............)
So if anybody has a friend outside of the forum who might want to participate then show him what the group buy is about and what bang for the buck it really is.
Gunni
tomislav
Post Sat Feb 25, 2012 10:38 am
Will you be doing more group buys in the future if there is enough interest at a later date?
craigieeb
Post Sat Feb 25, 2012 8:30 pm
Gunni wrote:So everything is officially set for the group buy to go along as we have 7 people ecu´s now.
I have basemaps for
:cool: :cool:
Mint! Thats One more item crossed off the M50 turbo build list :D
Gunni can you send me over your details and I'll get the monies to you mate
:thumb:
badassyas
Post Sat Feb 25, 2012 8:34 pm
tomislav wrote:Will you be doing more group buys in the future if there is enough interest at a later date?
Nooo he won't!! Get in now to help drive down purchase costs!! Lol only kidding!
Gunni
Post Sat Feb 25, 2012 9:11 pm
Around the same time next year. Unless there is explicit group interest.
Gunni
dot
Post Sun Feb 26, 2012 9:00 pm
another qeerey!!,If i use your base map for my m20 turbo do i just load it to my vems? and will i still have to configure the temp sensors, injectors and ignition and so on?
im pretty sure i can handle wiring it up i think configuring it all will lead to lots of :? head scratching
craigieeb
Post Sun Feb 26, 2012 9:09 pm
Fit it then load the relevant base map, then take it to gunni for a tweek/correct mapping
I hear he's ok with these kind of things :chuckle:
Gunni
Post Sun Feb 26, 2012 11:04 pm
The basemap contains all settings for everything. I will even load it before it gets shipped out for everybody and adjust it to your spec(injector wise, ignition wise). You then wire the ecu according to the base map settings.
I will be needing everybodies engine codes eventually so I can order the correct ecu, some M50´s have Hall effect sensors and some dont. so this needs to be clear. For M20´s no need or most single cam bmw engines.
If you are unsure a picture of the cam sensor will do the trick.
Gunni
Gunni
Post Sat Mar 03, 2012 9:55 pm
Just a reminder for those who are yet to pay to not forget before the 10th of March.
Also I´m still needing engine info for the following
Sag and Craig and Badassyas
Just to make sure I order the right configuration ecu.
Thanks guys,.
Gunni
craigieeb
Post Sat Mar 03, 2012 10:27 pm
Info sent...
sag
Post Mon Mar 05, 2012 11:49 pm
PMD
Gunni
Post Fri Mar 09, 2012 8:06 am
Tomorrow is the last day.
The current total looks like 10 participants. Which I must say is well done. I´ll try and keep things updated on expected delivery dates.
Gunni
craigieeb
Post Fri Mar 09, 2012 12:24 pm
Does that mean a further discount because of the larger order? winkeye
kris25
Post Fri Mar 09, 2012 6:24 pm
Haha i like your thinking craig :)
Gunni
Post Fri Mar 09, 2012 9:14 pm
Unfortuanately not.
this is as low as it goes I´m afraid.
Gunni
craigieeb
Post Fri Mar 09, 2012 9:15 pm
Worth a try
:lol:
