2.0 M42
Post Tue Feb 07, 2012 6:57 pm
Bored with the m40 auto in my touring allready.
Was talking to Dezzy today and with insurance in mind he was saying why not build a 2.0 or 2.1 m42 and has got me thinking.
Would i be right in thinking an m44 crank and rods with s52 pistons will create a 1947cc ? do the pistons need machining ?
does an m47 crank drop straight in or would it require machining to fit ?
its confuses me all this bore size and displacement calculation mallarky :mad:
redcar
Post Tue Feb 07, 2012 7:05 pm
Would a whole standalone engine management be required if this is achieved?
I think Tim had a 2.1 m4x
Post Tue Feb 07, 2012 7:06 pm
i'am sure you can just get the original done with a live remap
redcar
Post Tue Feb 07, 2012 7:09 pm
This is useful to discover what combinations of bits give what displacement :)
http://www.e30zone.net/e30zonewiki/inde ... roker_Info
Post Tue Feb 07, 2012 7:13 pm
i know but when it says custom piston what the fook is that suppose to mean :mad:
I want simple bolt together bits with minimal machining, and if anything needs machining i want to know how much need off and what bits :D
pac1982
Post Tue Feb 07, 2012 7:15 pm
I often thought about doing this when I had my IS but for the work I would rather do an M52 conversion, I know your thinking about insurance but I don’t think insurance would be much different for a 2.0/2.1 engine than an M52
Oh and btw glad you saw the light and decided to break that sorry turd of a compact you had :wink:
1990 BMW E30 318IS (Sold)
1990 BMW E30 316i (RIP)
redcar
The block would need boring to a size suitable for a set of custom pistons from JE or something. Are there plug and play pistons to create a 2.1 ?
Also, i think an m44 block is needed.
rix313
Post Tue Feb 07, 2012 7:18 pm
This maybe a helpful tool for you: http://www.motorenteile.mahle.com/eLIZA ... e/byParams if you select 'BMW' and 'Petrol' it will bring up all the details for the petrol engine pistons. M42/44 are on pages 9 and 10 and S** engines are on page 16. For each there is a detailed diagram which will tell you all info on the piston to be able to work out which ones you can use.
Hopefuly before you're head falls off searching some one will spring up with the exact info and put you out of your missery :mad: :D
There was some one who used a rover diesel rank which had the same throw but was too short. Not sure what happened of it, I think they got it to work but it needed extending, which is never perfect for an engine component.
An M44 block already has a larger bore which naturaly already gives you a couple more CC over an M42 block.
Post Tue Feb 07, 2012 7:23 pm
pac1982 wrote:I often thought about doing this when I had my IS but for the work I would rather do an M52 conversion, I know your thinking about insurance but I don’t think insurance would be much different for a 2.0/2.1 engine than an M52
it was always going to be broke for parts for my mothers one.
a 6 pot m50 will stand out an m42 wont
Catch my drift .....
Post Tue Feb 07, 2012 7:24 pm
rix313 wrote:This maybe a helpful tool for you: http://www.motorenteile.mahle.com/eLIZA ... e/byParams if you select 'BMW' and 'Petrol' it will bring up all the details for the petrol engine pistons. M42/44 are on pages 9 and 10 and S** engines are on page 16. For each there is a detailed diagram which will tell you all info on the piston to be able to work out which ones you can use.
i got to bore and got confused :mad:
i want a simple answer on what bits will create what :D
Alburglar
Post Tue Feb 07, 2012 7:36 pm
I have been researching exactly this. 2 types of
M47 crank, both can be used in m44 or m42. 88 mm stroke crank is easier to modify than the 90mm. All parts are available from metric mechanic and a 2.1 requires 87mm pistons. Custom means you just send the measurements to je a another piston firm and they make them. I am not totally up to speed on s50 and s52 piston sizes yet.
As for m44 crank- yes it fits, what rods and pistons you use also varies greatly.
M42 - rightness! with proper 4.27 LSD
Post Tue Feb 07, 2012 7:37 pm
so anything with bore 84 will fit ?
Post Tue Feb 07, 2012 7:42 pm
n42's and m52's have a bore of 84 so does that mean the pistons will fit in the block
how do i work out what other bits and pieces calculate too ?
rix313
If using an M42 block then 84mm, if using an M44 block then 85mm. If you got hold of some S52 pistons, you could send them to a specialist engine machine shop and they should be able to modify them for you if possible. This should save the cost of shiney new custom made pistons.
Post Tue Feb 07, 2012 7:44 pm
rix313 wrote:If using an M42 block then 84mm, if using an M44 block then 85mm. If you got hold of some S52 pistons, you could send them to a specialist engine machine shop and they should be able to modify them for you if possible. This should save the cost of shiney new custom made pistons.
So what would need to be modified?
Ps: did you get my pm :)
rix313
Post Tue Feb 07, 2012 7:46 pm
Alex wrote:So what would need to be modified?
I have this wierd feeling in the back of my head that the crown needs machining but that could be total bollocks :| .
Yeah, but I'm ignoring you :wink:
Post Tue Feb 07, 2012 7:47 pm
probably easier to build a 1.9 m42/m44 hybrid.
N53 pistons are 85 :D
rix313
Post Tue Feb 07, 2012 7:52 pm
You need to look at various dimensions, for example if you pick a piston with a crown height which is too high, you could end up slamming the valves into the top of the piston. You also need to have a piston which uses the same size gudgeon pin as the rod you intend to use, otherwise you can't join them winkeye
Have you had a look on M42 club, might be some info on there?
Here's a key for the Mahle website:
KH=compression height
VT=valve recess depth
MT=combustion chamber depth
Mdiam=combustion chamber diameter
GL= total length
S52's were only shipped out to the USA too so you'd need to get a set from over there. They're also the 86mm as are the S50 ones, so you would need to bore the block regardless.
The wiki could really do with a going over from some one who's done it too that'd help.
Alburglar
Post Tue Feb 07, 2012 8:18 pm
M47 cranks (88mm stroke)
E46 320d. 1997-2001. Not the M47N
E39 520d. 1999-2003
E46 318d. 2001-2003/04 Not the M47N
* 1999-2004 Rover 75 CDT
M47D20
* 100 kW (134 hp) and 280 N·m (207 ft·lbf)
o 1999-2001 E46 320d
o 2000-2003 E39 520d
* 85 kW (114 hp) and 265 N·m (195 ft·lbf)
o 1999-2001 E46 318d
90mm stroke crank
M47TUD20
* 85 kW (114 hp) and 280 N·m (207 ft·lbf)
o 2001-2005 E46 318d
* 110 kW (148 hp) and 330 N·m (243 ft·lbf)
o 2001-2005 E46 320d
o E83 X3 2.0d
* 2004-2005 Rover 75 CDTi
M47TU2D20
* 90 kW (121 hp) and 280 N·m (207 ft·lbf)
o E87 118d
o E90/E91 318d
* 120 kW (161 hp) and 340 N·m (251 ft·lbf)
o E60/E61 520d
o E87 120d
o E90/E91 320d
Also
99-04 rover 75 CDT
04-05 rover cdti
01-06 landrover freelander td4
Using M47N 90mm crank
If it can be used with E36 S50 B30 US M3 piston which has 86mm diameter and 32.8mm compression distance plus 135mm conrod length, the resulting displacement is 2,091cc (86mm x 90mm) with 1,5 conrod ratio. Off course you need to enlarge the bore to 86mm (2mm larger for m42 or 1mm larger for M44)
The total deck height will 211.80mm or it will sits 0.35mm lower than M42/M44 standard deck height.
The 88 stroke crank must
have the nose turned down
and a second keyway added
to secure the chain sprocket
and front harmonic balancer
hub.
Post Tue Feb 07, 2012 8:21 pm
8) Am learning :P
Looking at these
http://store.vacmotorsports.com/cp-pist ... p2312.aspx
If i got the bores widened to 86 mm and fitted these to a standard m44 block what would that give ? 2.0?
Alburglar
90mm crank needs an extension piece too.
It has less balancers and is a little harder to make work...apparently. I have just sold a car and I will be gathering parts for my build soon.
All pictures are from here:
http://www.metricmechanic.com/pdfs/metr ... ooklet.pdf
Alburglar
Post Tue Feb 07, 2012 8:24 pm
Alex wrote:8) Am learning :P
Looking at these
2.0 yes, there abouts.
Post Tue Feb 07, 2012 8:25 pm
Looking at these
Sounds easiest option.
May have to go down that route. if i'am honest all this machining crank is confusing.
If i emailed and asked for 87mm over size would that be too much for the block to take? assume that would be 2.1
would 88mm be taking the piS3
is it expensive to get engine blocks bored out
Alburglar
Post Tue Feb 07, 2012 8:32 pm
I'm gonna do m47 88mm crank, s50 86mm pistons and standard m42 rods. As long as it's safe to take 2.8mm off the piston height.
or i will fork out for the metric mechanic 137 or138mm rods and use s50 pistons in standard form.
Bored out m44 sounds good tho!
Alburglar
Post Tue Feb 07, 2012 8:35 pm
I don't think there will be enough meat between the bores at with 88mm cylinders (if any). A bore out and short engine build is not particularly expensive if you remove engine and strip it down to the block.
Post Tue Feb 07, 2012 8:38 pm
Alburglar wrote:I'm gonna do m47 88mm crank, s50 86mm pistons and standard m42 rods. As long as it's safe to take 2.8mm off the piston height.
or i will fork out for the metric mechanic 138mm rods and use s50 pistons in standard form.
as long as it will run, i'am new to engine rebuilds, ive stripped an m10 and m20 down before and know whats what in them. so want to make i as easy as possible.
If i bought 87mm pistons then along with getting the bores widened it will make a 2.1
How much does it cost to get them bore'd out ?
rix313
Post Tue Feb 07, 2012 8:40 pm
Awesome info there :thumb:
Post Tue Feb 07, 2012 8:42 pm
one more question then, will an m44 block bolt upto an m42 head and will an m42 engine managment loom and all hoses etc bolt to an m44 block :D
If i built one with the spec above and had it live mapped on standard ecu would 170bhp be achivable
rix313
Post Tue Feb 07, 2012 8:52 pm
Water hoses will all be the same. M42 engine loom should work. Bare in mind the M42 has the crank sensor on the front bolted to the timing case and the M44 has the crank sensor mounted at the back of the block near the flywheel. If you use a diesel crank you'd need to use the M42 system with a pulley wheel.
Post Tue Feb 07, 2012 10:33 pm
Think iam going to start saving for an m44 based 2.1 :)
rix313
Post Wed Feb 22, 2012 8:38 pm
