It's an Aug 86 320iSE
The drivers lock is fooked. The key turns but it does nothing. You cannot lock the door from inside either. The drivers door is permanently unlocked.
We can unlock and lock the boot with the key and the central locking relay clicks.
When I viewed the car I took the locking relay module out and it's bone dry and not corroded in anyway. Never seen any moisture by the looks of it.
The drivers door panel is already off.
Is there a way I can quickly release the other 3 doors? Without a quick fix I'm gonna have to remove all the seats and console out through the drivers door and remove the door panels forcibly and actually muller the mechs to relaeas?
Thanks in advance
Trev
