snapped lollipop bolt in chassis HELP!
- Brianmoooore
If he tries to drill/extract/tap this bolt out, I'm more than certain that his next post afterwards will be along the lines of "how do I remove a broken extractor/tap from the hole"!
There is only one sane way of removing this bolt, and that is to weld a nut onto the protruding bit, with the heat turned fairly well up. The heat and thermal shock will unseize the bolt, and it will wind out.
hahahaha so trueBrianmoooore wrote:If he tries to drill/extract/tap this bolt out, I'm more than certain that his next post afterwards will be along the lines of "how do I remove a broken extractor/tap from the hole"!
Demlotcrew
No E30 i know of has a captive sub frame bolt with a thread holding it in?
Tom_Maverick
+1..Demlotcrew wrote:No E30 i know of has a captive sub frame bolt with a thread holding it in?
I was going to say the same! damn you.. fast typing git..
Demlotcrew
I think we need to hold a race, i will bet £50 i could get the bolt out first with no damage.
Just need to find two more turds with snapped bolts.
Tom_Maverick
or just wait till he does the other side..Demlotcrew wrote:I think we need to hold a race, i will bet £50 i could get the bolt out first with no damage.
I'd have that out of there in minutes.. you haven't seen seized bolts like a MK2 granada.. I swear they deliberately cold-weld everything in at the factory..
Good for you - best of luck!
BATTS91 wrote:well i should have this sorted tomorrow just got off the phone to a toll hire company got a mig welder coming tomorrow £30 for a whole week
You can do your diff while your at it !
pacerpete wrote:BATTS91 wrote:well i should have this sorted tomorrow just got off the phone to a toll hire company got a mig welder coming tomorrow £30 for a whole week
+ a yard full of scrap turds
Tom_Maverick
stance?bodger wrote:will be like the end of an era once this bolts out, what will everyone talk about?
I'm sure there will be a detailed 'thread' analysis afterwards...
Tom_Maverick wrote:stance?bodger wrote:will be like the end of an era once this bolts out, what will everyone talk about?
Diffinpacerpete wrote:BATTS91 wrote:well i should have this sorted tomorrow just got off the phone to a toll hire company got a mig welder coming tomorrow £30 for a whole week
Demlotcrew
So you use an example where the bolt is twice as big, does not have a thread that can be damaged while drilling and tapping and could have easily been punched out instead? Next you'll be telling us you retapped the thread!VW-will wrote:I never said the subframe bolts had captive nuts... Drilling a bolt is drilling a bolt being a captive nut or what ever, same $h1t different smell.
I don't know what's worse, your stupidity for assuming the sub frame bolt needs to be drilled out, or saying that it's easy since youve never actually done it.
Demlotcrew
Will I Am innit bruv, 4" dish, red cubes and on route 66 with a tapped sub frame bolt.
Tom_Maverick
less of that.. I've spent a lot of time fiddling with dubs and it hasn't turned me into a retard.. (I worked at a dub performance specialist and I was even featured in PVW many years ago)pacerpete wrote:It's a dub thing, man !
don't blame the marque.. blame the divvo driving it..
Tom_Maverick wrote:less of that.. I've spent a lot of time fiddling with dubs and it hasn't turned me into a retard.. (I worked at a dub performance specialist and I was even featured in PVW many years ago)pacerpete wrote:It's a dub thing, man !
At least you have seen the light and now have a proper, albeit councilled , turd
Demlotcrew
We only have your word on that.Tom_Maverick wrote:hasn't turned me into a retard..
Tom_Maverick
hey at least I can spell and use some sort of grammar.. A skill that would appear to be lacking here on the Zone...Demlotcrew wrote:We only have your word on that.Tom_Maverick wrote:hasn't turned me into a retard..
and as for my council turd, you obviously haven't seen it in it's winter rightness..
Demlotcrew
Thats a very good point! The language skillz of the zone are pretty shocking!Tom_Maverick wrote:hey at least I can spell and use some sort of grammar.. A skill that would appear to be lacking here on the Zone...
Tom_Maverick
I'm amazed that some people on here actually managed to fill in the registration form without the help of a carer or guardian..Demlotcrew wrote:Thats a very good point! The language skillz of the zone are pretty shocking!Tom_Maverick wrote:hey at least I can spell and use some sort of grammar.. A skill that would appear to be lacking here on the Zone...
Demlotcrew
I bet that would never pass the hammer test.
Looks like you welded a seam on the chassis rail and totally missed off the lolly pop
The CAB looks interesting too!
If I see you on the roads I will call the police.
Andrew
Andrew
tidy weld? specsavers mate..the weld is penetrating the chassis and nowt else, and round the side is a series of tacksross_jsy wrote:You welded the lollipop on?
Classay turd you have there sir! What happened to welding a bolt to the end? At least the welds look tidy!
Its a mess, you are a retard..Are you related to Tay the crossdresser?!BATTS91 wrote:i pronounce this job bodged !
rented a welder as it goes a siegen 130 mini mig as a few of us were talking about earlier good welder
nooo no police, drive into it and put the poor thing out of its miseryDemlotcrew wrote:I bet that would never pass the hammer test.
Andrew
