here is the pic of the fueses and relays not sure which ones to check if any one could give me some pointers what esle should i check?
P.S dont want to tow it again to a workshop
thanks it was a relaymrLEE30 wrote:1 check fuse 11
2 remove a spark plug and confirm you have a spark while cranking
3No spark? then check for power at the coil, and the crank position sensor(and wiring)
4Yes spark then remove fuel pump relay (located in the smaller relay cover close to the air flow meter located in middle slot(not in the picture above) then bridge female pins 30 and 87 and try to start. Remove wire after trying. If it starts then relay at fault, if not then check for power at fuel pump with the wire bridge in place using a test bulb. Power here means pump is likely duff
If there's power at the pump, and the pump isn't running, then the pump has failed.E30_Crazy wrote:Just wondering, how would power at the pump mean that the pump is bad? I'm following this trying to figure out why mine won't start. Tried swapping the relay, but no good.
I figure that power at the pump with the wire bridge would mean the relay is bad, not the pump?
Should be one in the toolkit on the boot lid.E30_Crazy wrote:Don't have a socket that'll get the spark plugs out. .
