Best engine to turbo? completed & the results are in :)
Brady you wrong'un
craigieeb
That is a canny manifold, but wrong for my turbo,ross_jsy wrote:Don't know if this is any help? Going cheap. Was going to buy it today until my promised "big payrise" evaporated:
http://www.e30tech.com/forum/showthread.php?t=111548
the turbo i'v got is a "twin scroll"
so the manifold I/we make will have to be split into 2, say, bank 1,2 and 3 to one side of the "split" T4 flange and 4,5 and 6 to the other side,
and then 2 branch off pipes for the wastegate/s
so yeah if i bought that it would just basically get hacked to bits....besides check my sig below
cheers for the heads up tho dude
Do you want to lick my snail Mr JonesE30BeemerLad wrote:Brady you wrong'un
No way no how, the turbo will be sitting more or less behind the lights (ish),maxfield wrote:You may be cutting your bonnet if it's going top mounted.
There'll be NO cutting of my carbon mr
I'll start a new thread when iv got all the bits and start making the manifold,
Which wont be long now
M50 Turbo!!!
I shall say no more
There is NO need to cut the bonnet with that thing.
Alot bigger has been fitted to E30´s without bonnet cutting.
It´s not split pulse which is the prime purpose of the turbo he bought.ross_jsy wrote:Don't know if this is any help? Going cheap. Was going to buy it today until my promised "big payrise" evaporated:
Re Vanos vs non vanos lumps, I've had a look into controlling vanos via a standalone such as megasquirt.
Single vanos is pretty much a simple on/off switch, the system is active from just above idle to approx 5000rpm and basically just needs +12V to turn it on. MS can control single vanos quite easily so I imagine VEMS will as well.
As to whether vanos would be a help or a hindrance on a high power turbo motor, I'll wait for someone with more experience to confirm!
craigieeb
Im not to sure on the vanos side of things,
I think gunni was working on something with the vems, so it could either be controlled or switched off..?? not sure which tho
I played it safe and went for the non vanos, which actually,
turned up this afternoon
And after a little fettle looked like this
just need to pull the head tomorrow and give the whole thing a bit of a freshen up
seeing as the plugs look like this,
mmmm Tasty
mmmm Tasty
M50 Turbo!!!
I shall say no more
Thats been well looked after!
You fitting a thicker headgasket? I'd defos be getting the head pressure tested and skimmed aswell.
New oil pump inners would be a good idea aswell. That snail will like it's giness to be on tap.
craigieeb
The arp head bolts and the MLS headgasket have just cleared US customs
Dont think the head needs checked, it was running fine when/before it was removed,
and it looks ok to me
It'll not be getting a skim either, it'll mess up the compression
I might treat it to a new oil pump and some new gaskets tho
M50 Turbo!!!
I shall say no more
Vanos is your friend. The simple M50 vanos any ecu can run, the variable S50 vanos a VEMS can run as well as most (not all) more expensive ones. None that are cheaper then a vems .mr_dink wrote:Re Vanos vs non vanos lumps, I've had a look into controlling vanos via a standalone such as megasquirt.
Crageeb {speed FREAK and ex nitrojunky}
this sounds like fun,giz a shout when the weather gets a few degrees warmer m8 and you have the build car.
many hands make light work
+ a yard full of scrap turds
craigieeb
Will do Mick,
need someone to do all the work while im drinking tea and eating bacon sarnies
Back to the diff situation....
I'v decided Im going to be using the E36 (328is) box,
can anyone work out what ratios will give me what,
I want a diff that is going to give good acceleration and that doesn't run out of puff or be on the limit at around the 150-160 mark
leeparkes wrote:328i/S50 box, there a direct 5th though so you will need a long diff, ie if your going for 500hp it will need to be around 2.93 (or lower)
This blokes got some tasty ratio diffs.
http://www.e30zone.net/modules.php?name ... c&t=209939
M50 Turbo!!!
I shall say no more
leeparkes
Iirc a 3.25 is the equivilent of a 4.0 with an overdrive box and a 2.93 is close to a 3.64.
So yes id go lower than 2.93 with that much power.
Nice purchase btw.
Nice purchase btw.
craigieeb
Nice1
I think it'll have to be much lower than the 2:93
the 2:93 coupled with the 328i box will only give a top end of 158,
and the 2:65 will give a top end of 175
Thats going off the info given in this link...
http://www.endtuning.com/gearratios.html
tyre size 225-40-17
(link stolen from jimbob ;)
dont know how accurate this thing is,
but i thought i would of seen more top end than 175 with the 2:65 diff fitted
tyre size 225-40-17
M50 Turbo!!!
I shall say no more
craigieeb wrote:Hang on, will the 6 speed box (E36 m3) bolt straight up to the M50?
The S50B32 6 speed box will bolt straight on. It won't like the power you want to put through it though.
Any specific details of the 6speed being weak? I have not heard that before.
isn't it the synchros that go on the 6sp boxes?
Iirc it is something to do with the synchros, part un available to buy afaik.
Anyone know where recon S50B32 box's can be bought??
craigieeb
I'v been asking around about gearboxes,
and it does seem like the M3 box is more prone to, jumping out of gear, not going into gear, and just basically failing,
if I had got a box from the M3 and 100 miles down the road it goes "pop" I wouldn't be to happy, not only are they 5 times the price of the 328i box, there about 5 times the weight
so I'v opted to go for the 328i box
think it needs the seal changed
iv got the 328i manual prop and im getting a hold of the 2:65 slipper
(bit of a noob question..... what gear linkages should be used with that box? )
M50 Turbo!!!
I shall say no more
craigieeb
A one of these.....?Jhonno wrote: I have a nice double shear shifter linkage from AKG if you are interested..Replaces the single shear bottom arm.
http://www.akgmotorsport.com/catalog/ca ... 20Shifters
A bit overkill for me
but if it's only a 10a
M50 Turbo!!!
I shall say no more
craigieeb
Dont you just love shopping in america
If only the ARP studs and the MLS gasket were that cheap,
A big
to the guys over the pond for sorting the invoice so I wouldnt have to pay a small fortune in customs fees
Woohooo time to crack on I reckon
ARP's to hold the sucka down
and a nice chunky gasket to get the compression just right
A big
M50 Turbo!!!
I shall say no more
craigieeb
Cheers dude,ross2009 wrote:liking it muchly
I haven't been doing much lately due to family problems and also the car had a bit of a fight with a roundabout
But now im back on the ball,
and looking for an intercooler...
I'v just been looking at your pictures Ross mate, and came across this...
what size is that mate? and do you know what it flows to?
is it anywhere near this...
http://cgi.ebay.co.uk/ws/eBayISAPI.dll? ... 1917wt_981
M50 Turbo!!!
I shall say no more
