1994 318i Touring - Time to Sell :(
Sun Jan 22, 2012 10:37 pm
Coming together nicely. 8)
Sun Jan 22, 2012 10:40 pm
Dezzy wrote:Its a credit to you Alex.
There isn't many lads your ages that don't lust after saxo's etc.
Great effort to bring this one up to scratch. Looking forward to having a nose around it 8)
Thanks Dez
Ive got some new Rimmzzz for it innit, probably 50% council however one needs a tyre so i will still be up once its on the road, i'am litrally waiting for the 4th years no claims to turn up anytime now
csl
Sun Jan 22, 2012 11:05 pm
Leather looks great! 8)
Tue Jan 24, 2012 10:53 pm
Thanks for comments.
Its probably going to be the most attached to e30 ive ever owned, i'am allready worried someone may twat it when it goes onto the road.
Wrote a lovely letter yesterday to the original owner, all receipts from 1995 till the most recent had the same address so chances are he is still at that address. I included plenty of pictures and gave him my email address and address. i explained what i had done, explained i will be taking it to classic car shows etc. and also asked him for some original pictures of it if he has some. Will be interesting to see if i get anything back. I wait with anticipation :D
Also found out that the car was originally supplied with cloth interior. given its a one owner car, and seeing where the fella lives along with the mind boggling prices on the recipts i'am wondering if he purchased a brand new interior somewhere along the lines, the rears just look too new, if that makes sence, they still have a "texture" finish to them same goes to passengers seat
greentouring
Wed Jan 25, 2012 5:45 pm
Epic thread, mate! Very impressed with what you've done and wish I'd been as level-headed when I was your age. Keep up the good work!
Mon Jan 30, 2012 11:35 pm
Started fitting some car audio, unfortunately the standard set-up isnt good enough for me
The setup is as follows
Nakamichi CD-400 Head unit
Loudest.com 90w RMS 4" components in Rear
Vibe Black Hex 75W RMS Components in Front
Vibe 4 Channel AMP 4x 100W RMS
So Plenty of power.
took about 3-4 hours to do what seems like not a lot but i wanted to do everything properly using heat shrink etc.
started by removing rear panels in the touring, pain in the arse these.
first problem was when i removed the speaker pods, the speakers that were going in wouldnt fit depth wise, so had to be creative and smash a hole in the bottom for the magnet to stick out, i used the original foam inside to cover the hole i had made for the magnet. aswell as that the speakers seemed very slightly wider than stock so had to do some trimming to the hole. but got there eventually.
no block connectors this time
excuse the excessive trimming
this is where the amp is
The only e30 ive owned where there isnt a tiny bit of rust where the fuel filler goes.
Back together
after plenty of swearing i managed to get it back together along with all the wiring from front speakers to back of the car, earth, power lead, rca and remote cables.
today i fitted front comps and connected the amp up in cubby compartment, also fitted my nakamichi head unit. only thing i need to do now is modifiy the tweeters for the aftermarket ones and connect them up. although this is the only pic i have
at last i have a glovebox and all trim in on the passenger side. to be honest this was a fooking pig to do as there was slight damage to the footwell so i had to remove foam from the carpet and trim the speaker panel down ever so slightly but you would be non the wiser now.
while the battery was on charge i used a wire wheel to remove any loose crap from the battery tray and soaked it in loads of krust for 3 hours then gave it a coat of zinc primer, not a permanent fix but should slow it down for now.
krust
Zinc primer
Ready for a coat or three of mauritus blue
Its getting taxed and insured on Monday, cant wait :D
johnl320
Mon Jan 30, 2012 11:39 pm
Good job, lovely car mate
Mon Jan 30, 2012 11:54 pm
Nice work there Alex :cool:
chh137
Mon Jan 30, 2012 11:59 pm
Top job Alex. Enjoy getting on the road tomorrow.
Tue Jan 31, 2012 12:01 am
Cheers Guys
Think i will invest in a decent underseat subwoofer next.
next monday its going on the road not tomorrow :D
chh137
Tue Jan 31, 2012 12:09 am
My mistake Alex.Enjoy next Mon . fingers crossed for good weather.
Tue Jan 31, 2012 12:10 am
chh137 wrote:My mistake Alex.Enjoy next Mon . fingers crossed for good weather.
Weather dont bother me, it was 2 Degrees all day today and i was never cold.
Winter wheels with snow tyres will be fitted on Sunday till the gritters go away :D
The_Haywood
Tue Jan 31, 2012 1:55 am
a gritter blasted my touring today :( i've done so well lately to avoid them but i was sat waiting to pull out of a junction and it turned in to where i was... i hate the things :(
Tue Jan 31, 2012 7:07 am
Alex get a sh1tload of waxoyl on that battery tray before the battery goes back in :wink:
If its started to go a bit in the engine bay check the other side too :
Mine seemed OK but I got the wire brush on it and smoothrited/waxoyled it to be sure :)
Sun Feb 05, 2012 6:16 pm
Getting Insured and Taxed tomorrow cant wait.
Finished the car audio off today, the only thing i need to do is fit tweeters but the wires are all connected. Also fitted Snow tyres, mainly because the bbs need 4 new tyres. Kinda like the pov spec look :o:
Got all the interior back together and tweeked about with the headlights to raise the aim a little. fitted the mats out the e36 as i dont want the e30 ones getting ruined.
Everyone must of thought i was mad working in the snow but surprisingly it was warm with the sun out, had to take some layers off
So here it is finished for now, kickdown works correctly now and will rev to the red line before changing up, private road obviously :)
Sun Feb 05, 2012 6:27 pm
Cracking car this - a credit to you Alex
8)
Sun Feb 05, 2012 8:31 pm
Cheers Rob
Looked at the battery tray underneath too, was perfect not a spot showing through :D
chh137
Sun Feb 05, 2012 9:17 pm
HAPPY BIRTHDAY for tomorrow Alex.have a great day.
Car is an absolute credit to you, enjoy it.
Charlie.
Sun Feb 05, 2012 9:19 pm
Cheers Got a 150 mile trip to do on Wednesday down to Cheshire, should give it a good run out :D
Mon Feb 06, 2012 9:00 am
It's Monday Alex, so
Happy Brithday! :D
Sanchez
Mon Feb 06, 2012 6:24 pm
Is that your rear wash wipe switch glowing when not in use? My bulbs must have gone.
Mon Feb 06, 2012 9:31 pm
Cheers Rav
and yes it is
I've racked up 120 miles today and i'am bored with it allready :(
Manual conversion and Lightweight Flywheel prehaps ?
Mon Feb 06, 2012 9:35 pm
Alex wrote:Cheers Rav
and yes it is
:banghead:
If you're gonna change the box you may as well bolt a proper donk to it :twisted:
Mon Feb 06, 2012 9:37 pm
Save up for an M52.
Mon Feb 06, 2012 9:39 pm
Not being funny but a 525e engine sounds attractive.
obc says i'am averaging 22 mpg at the moment :mad:
Dezzy
CR24v it's a lifestyle
Mon Feb 06, 2012 9:40 pm
bss325i wrote:Save up for an M52.
THIS
Mon Feb 06, 2012 9:41 pm
Alex wrote:Not being funny but a 525e engine sounds attractive.
As in from an E28 :eek:
Too old.
M52 it - modern powah 8)
Mon Feb 06, 2012 9:45 pm
Too old.
or a 325e if you dont live in the uk :D
40mpg can be achieved apparently
Mon Feb 06, 2012 9:47 pm
Too old.
If you are bored of a 318i auto you would get bored of an M20 that revs to 4k!
Mon Feb 06, 2012 9:49 pm
bss325i wrote:
Alex wrote:
capri_rob wrote: As in from an E28 :eek:
Too old.
What i really want is an s52 but no chances of that :cry:
Mon Feb 06, 2012 9:52 pm
Ive also got an issue where the passenger door has locked itself and wont open with key, handle and door pin wont pull up :cry:
Mon Feb 06, 2012 9:53 pm
Convert your car to manual then save up for an M52. The M52 will bolt up to the M40 manual conversion to by converting it to manual now will not only make more enjoyable now, it will also be a step in the right direction toward an M52 conversion.
Mon Feb 06, 2012 9:55 pm
Makes Sence, wont cost much to do either i guess, dont get me wrong i like it being an auto makes its lovely to drive, but somehow boring :(
Mon Feb 06, 2012 10:03 pm
Autos really suit engines with plenty of low down torque like turbo diesels, 6 pots petrols and bigger.
Not revy 4 pots although M40's are quite torquey for what they are.
Mon Feb 06, 2012 10:17 pm
Diddlers got one in his garage doing nowt Alex. :D
