The first problem I had was the engine cutting out and not starting. And when I did manage to get it going it was idling badly and miss firing most of the time. Excessive fumes seemed to be coming from the exhaust at times as well.
When the car would often fail to start at all, the engine would crank and then suddenly the cranking would stop with a "Clunk"
I have an after market Scorpion SA30 Alarm/Immobiliser system fitted and I was thinking it could be a problem with it, not allowing the engine to fire up or making it run poorly and sometimes suddenly cut out.
I have also checked the possibility of it being the Air Control Valve (ACV) But after swapping mine for another that I have and expect to be working the same symptoms occurred. Along with this I checked for any holes or cracks in the air hoses, but nothing. But would this really cause the engine to stall? Or fail to start, I didn't think so.
So lastly I was thinking it could be a Crank Position Sensor, has any one had any trouble with these? Any help would be fantastic as I'm at my wits end.
