injectors
mrb27
Post Sun Jan 29, 2012 10:19 pm
hey all, just whipped my injectors out for a quick peep and to give them a quick blast of cleaner to keep them clean. i have a small compressor that i set to 40 psi, set up to a pressure canister that will hold cleaner and pump it out when i pull the trigger winkeye
after flowing the cleaner through, the liquid was a bit murky as expected, but i was wondering if the injectors should spray a mist or a jet, all of the injectors are letting out a steady clean jet. but i was expecting a mist from them. does the pressure given to them make a differance to the spray pattern at all? and should it be a jet of mist?
i was going to lay a towel across the rocker cover, plug the injectors in and crank the engine over to see what the pattern was like but i thought id ask u guys first :wink:
Uploaded with ImageShack.us
Post Sun Jan 29, 2012 10:25 pm
injectors "pulse" which is probably why you're not getting this without them connected.
Not sure if 40psi through them is the answer considering the fuel system usually operates at 3psi
mrb27
Post Sun Jan 29, 2012 10:48 pm
oww 3psi lol, that might be why im getting a jet! :mad:
ill plug em bk up and see how it runs, it was just a quick clean to keep things tip top tbh,
Post Sun Jan 29, 2012 10:49 pm
3 bar, not 3 PSI! A not insignificant difference between the two.
chh137
Post Sun Jan 29, 2012 10:52 pm
3 bar approx 45 psi
Post Mon Jan 30, 2012 7:34 am
Send them to injectortune - £10 per injector for a proper refurb.
mrb27
Post Mon Jan 30, 2012 8:22 am
yh, going to in a month or so winkeye
hongkongfuey
Mad-tango-geezer
Post Mon Jan 30, 2012 10:34 am
i have a spare set you can use if you need?
with cars like mine,
