after flowing the cleaner through, the liquid was a bit murky as expected, but i was wondering if the injectors should spray a mist or a jet, all of the injectors are letting out a steady clean jet. but i was expecting a mist from them. does the pressure given to them make a differance to the spray pattern at all? and should it be a jet of mist?
i was going to lay a towel across the rocker cover, plug the injectors in and crank the engine over to see what the pattern was like but i thought id ask u guys first
