Any ideas....?
M20 sounds likes a can of marbles....
oomz1975
Like a diesel doesnt sound right
Does the oil pressure light come on and go out as it should ?
Could be oil pump ?
Could be oil pump ?
e301988325i
If you have a tubular manifold fitted? it amplifies the noises and makes everything sound much worse than it is.
I said:
e30topless said:
lock the wife in there
- E30 Zone Meets/Events Team
Was the engine cold or warm when you adjusted them?
oomz1975
oomz1975
What did you adjust them too??
0.30 is when the engine is warm, and 0.25 when the engine is cold.
oomz1975
0.25.....
I have noticed recently when driving for longer than 15mins, the oil light the does start randomly flickering.
Maybe coincidence, but this is also when the engine got noticeably louder.
Oil level is spot on & was changed not that long ago too.
Could this be a sign of the oil pump on its way out?
Sounds like you don't have enough oil pressure for it to flicker.
You didn't lean on the oil spray bar when you did the tappets by mistake??
oomz1975
Does the engine drop revs when you remove the rocker oil cap??
oomz1975
No, if the revs drop, then you have oil pressure.
oomz1975
oomz1975
Started the touring up this morning, took off the oil cap, the revs did drop a touch.
Didn't leave it running long enough to see if it was any different once warmed though.
I'm pretty sure it's the oil pump, which I know is a pig of a job to change.
Will probably change the engine mounts as they are looking f***ed, as well as the sump gasket, sump plug & washer.
Any advise on what else I should check/do/replace at the same time will be appreciated.
The whole bottom end of the engine?oomz1975 wrote: Any advise on what else I should check/do/replace at the same time will be appreciated.
e301988325i
Was thinking that, would be cheaper just to swap the engine with a known goodun.Brianmoooore wrote:The whole bottom end of the engine?oomz1975 wrote: Any advise on what else I should check/do/replace at the same time will be appreciated.
I said:
oomz1975
Tom_Maverick
I found changing the spraybar makes a MASSIVE difference.. they are about £40 from BMW and it's amazing how blocked and ropey the old one will be when you get it off.. oter than that it does sound like the oil pump.. although that's quite rare on an M20!
Sounds like your engine is knackered in need of a rebuild. The tappet setting for the engine when hot is 0.35 not 0.3
Chances are the oil pump won't be too bad
You can drill the holes out on the spraybar to increase oil flow - just done mine with a 1.5mm drill which only took the holes out slightly.Tom_Maverick wrote:I found changing the spraybar makes a MASSIVE difference.. they are about £40 from BMW and it's amazing how blocked and ropey the old one will be when you get it off.. oter than that it does sound like the oil pump.. although that's quite rare on an M20!
After taking advice on here I had it acid dipped and have also blasted it through with brake cleaner. Tape up the spray holes first, then tape up all but one at a time to clear the holes individually.
Paying £40 for a bit of pipe with holes in is a last resort !
hongkongfuey
- Mad-tango-geezer
ive got a good, hi comp bottom end if you need?
with cars like mine,
clipper
I have heard of the spraybar being cleaned by threading a motorcycle clutch cable inner (like a bicycle brake cable but a bit fatter) through it, than the cable was clamped into the chuch of a drill and the drill turned on, spinning the cable inside the spraybar.capri_rob wrote:You can drill the holes out on the spraybar to increase oil flow - just done mine with a 1.5mm drill which only took the holes out slightly.Tom_Maverick wrote:I found changing the spraybar makes a MASSIVE difference.. they are about £40 from BMW and it's amazing how blocked and ropey the old one will be when you get it off.. oter than that it does sound like the oil pump.. although that's quite rare on an M20!
Gets out a load of crap apparently.
Tom_Maverick
lubes the entire cam and valvetrain.. I'd say £40 is fairly cheap.. also the pipe is flaired at each end and is only meant to be fitted and removed the once as these flairs crush.. you get leaks if they don't mate up properly.. also the holes are meant to 'squirt' oil at the camshaft lobes.. if you drill it out you may not be increasing oil flow but instead you may decrease the 'squirt' at the centre of the bar.. although I have heard of tricks to increase pressure to the centre holes I'm not sure what they are or if they work!capri_rob wrote:Paying £40 for a bit of pipe with holes in is a last resort !Tom_Maverick wrote:I found changing the spraybar makes a MASSIVE difference.. they are about £40 from BMW and it's amazing how blocked and ropey the old one will be when you get it off.. oter than that it does sound like the oil pump.. although that's quite rare on an M20!
