Painting subframe and trailing arms
Grrrmachine
E30 Zone Wiki / Team Member
Post Fri Jan 27, 2012 6:15 am
Hopefully the back end will be reattached to the car this weekend, so I figured I'd paint what I can before it all goes back together.
Is there any special technique or prep I should do, or is it just a good degrease and loads of Hammerite?
redcar
Post Fri Jan 27, 2012 6:42 am
Shot blasted then powder coat :)
Grrrmachine
Post Fri Jan 27, 2012 6:45 am
No time or money for that. The best these things are getting is a brass brush on the drill :D
Post Fri Jan 27, 2012 7:33 am
Grrrmachine wrote:No time or money for that. The best these things are getting is a brass brush on the drill :D
I did that on my beam and it didnt really touch it :(
It will clean it up a bit but won't get in the fiddly bits and won't get a good smooth surface.
Blasting & powdercoating is really the way to go :
I did my front subframe in smoothrite and whilst it looked OK its not a patch on a powdercoated finish :
eire30
Post Fri Jan 27, 2012 9:05 am
wish my dog could do powder coating as well as that....would save me a fortune! :D
Jos
Post Fri Jan 27, 2012 9:28 am
get one of those twist wire brushes for the grinder, lethal on limbs but effective for cleaning the main areas. The niggle bits where the trailing arms will still need some manual scraping.
'94 e36 tree climber
Post Fri Jan 27, 2012 9:30 am
Wouldn't recommend Hammerite for car applications. It has to be laid on in extremely thick layers and is very brittle and easily chipped as a result. I normally use black enamel intended for agricultural use.
Post Fri Jan 27, 2012 9:32 am
POR15
Jozi
Post Fri Jan 27, 2012 11:00 am
Brianmoooore wrote:Wouldn't recommend Hammerite for car applications. It has to be laid on in extremely thick layers and is very brittle and easily chipped as a result. I normally use black enamel intended for agricultural use.
I agree with this, I painted up parts with hammerite and the slightest knock makes it chip. Their primer on the other hand seemed to hold up well!
Knotted wirewheel for cleaning :thumb:
Grrrmachine
Post Fri Jan 27, 2012 11:55 am
I'll switch to the grinder then. And I've picked up some enamel paint for metal, so I'll give that a go.
It doesn't need to be pretty, it just needs to stop the winter salt eating away any more of my car :D
Post Fri Jan 27, 2012 2:02 pm
POR15 as my post above. Rock 'ard innit.
Grrrmachine
Post Fri Jan 27, 2012 2:34 pm
Can't get it over here though Jhonno. If it's got a brand name, I can't get it.
Post Fri Jan 27, 2012 9:31 pm
If your not going to go through proper paint stages with decent (expensive) gear then you may as well just wire brush it all by hand and bang a load of waxoil on. It will stop any rusting that is going on and keep water out of all other areas. Removing the coating down to bare metal is a bad move if your not going to replace it properly.
bigbird76
Post Sat Jan 28, 2012 10:10 am
POR 15 here also
Leigh
Grrrmachine
Post Sat Jan 28, 2012 11:21 am
All good info, cheers guys. I've attacked it with the angle gringer/knot brush, but not to the point of removing all the existing coating; just the scabs and pimples where the rust has taken hold. Then things got a wipe down with degreaser, and then slapping on this enamel stuff; thinned a little because it's so cold here at the moment (minus 12!)
So we'll see how it holds. Not a pro job, but can't be worse than leaving the rust to fester.
