engine swap
matt86
Post Thu Jan 26, 2012 1:47 pm
Hi I have got a 92 320i convertible aand was thinking of putting the 325i engine in.
How difficult is it?
I assume engine mounts, subframe etc are all the same, but is the wiring loom, ecu and gearbox different and are they and modifications required?
Thanks very much
Matt
maxfield
Post Thu Jan 26, 2012 1:53 pm
Looms are the same. Ecu's are different.
You can put a 2.5 on the 2.0 box but they're not as strong. Although I'm assuming you'll be leaving the engine standard then it should hold up.
As for mounting. Straight in.
Do a search been convered a lot.
Ajsingh
Post Thu Jan 26, 2012 6:14 pm
Im running a 2.7 on a 2.0 gearbox, 10,000 miles later and its going good.
E30 Crazy!
Post Thu Jan 26, 2012 6:29 pm
As long as you get a facelift 325i donk its about the easiest swap you can do.
Almost certain you will need to swap to the 325i exhaust too though.
Good luck :D
matt86
Post Thu Jan 26, 2012 7:47 pm
Just out of curiosity I though the 2.5 was the largest engine in the e30's apart from the m3, how do you get a 2.7 is that rebored?
Can you do a powerplant conversion like with the corrado and golf I had I had a 2 litre block with a 1.8 head and they went really well, could you do something similar with a e30 block?
What's the best way to get more power without getting overly complicated, I believe the 325i is 171 bhp standard, so could you put a performance cam in and induction kit and acheive around 190 bhp? If you were to do this would it idle lumpy and put the timing out?
Thanks to all for the advice very much!
Matt
ross2009
Post Thu Jan 26, 2012 8:09 pm
bmw made there engines pretty much spot on as they are
a 2.7 is what they used in the alpina models and is made up from a eta or the m21 2.4 diesel crank 2 ltr rods 2.5 pistons and a 2.5 head you can even push it to a 3 ltr
yeah a good exhaust a cam maybe and a good chip will give you about 190 200 bhp :)
have a read
http://en.wikipedia.org/wiki/BMW_M20
Turbo M20
v8 project 6.0 twin turbo
matt86
Post Thu Jan 26, 2012 8:27 pm
Oh right that's interesting, might keep it simple for now and put the 2.5 engine in, stainless manifold, performance camshaft and a induction kit.
Matt
ross2009
indunction kit dont do crap mate stick with the air box
Turbo M20
Grrrmachine
E30 Zone Wiki / Team Member
Post Thu Jan 26, 2012 8:41 pm
Our own wiki has more info on M20 Upgrades:
http://www.e30zone.net/e30zonewiki/inde ... n_Upgrades
As has been mentioned, forget an induction kit. And don't get any old manifold, there's only one out there that's worth fitting, and it's the BTB. And if you're going to fit a cam, you'll have to chip the system to match.
ross2009
Post Thu Jan 26, 2012 8:42 pm
and the btb iant cheap i can tell ya :)
Turbo M20
