hi all
i am new to the BMW motorcar devition i do have a R60/5 motorcycle for the last 15 years problem is that my newly bought 1985 320I left me standing next to the road twice this past week and after a wile she starts up without any problems i have replce the distributer cap rotor and coil but no lusk what should i do Blessings Jurgens
320I cutting out with uge backfire
skipunda
We have a little to go on there, Jurgens. Could you describe what happens when the car stops working while driving?
Does it also take a while to start in the morning?
Chris
sweep
Afm?
Jos
backfire would suggest over fuelling? AFM, injectors leaking, blue temp sender. All of the above?!
'94 e36 tree climber
bodger
check the multiplug under the inlet manifold, peel the rubber boots back on both halfs of the plug and check for corrosion/breaks in the wires
