just a few technical questions
aceifty
Post Sat Jan 21, 2012 5:13 pm
on my m20b28 the head had cracked. just waiting for the replacement head.
1) i was thinking of having the head ported and polished but my bro said to me not to get it polished as it is no good. so now dont no what to do, what do you guys/girls think about ported and polished heads.
2) the other thing im thinking of doing is a miller MAF conversion with the W.A.R chip. has anyone on here done this? is it any good?
3) should i get the valves grinded as normal or do the 3 angle valve grind
4) this is the second time that i have had a broken rocker. is there anyway i can make them stronger as i dont wont another broken one nor do i want to spend 700 notes on some.
aceifty
Post Sat Jan 21, 2012 7:33 pm
bump
kam-325i
Post Sat Jan 21, 2012 7:44 pm
1, Porting and Polishing.
It depends on who does it. If you are just randomly taking chunks out of the head, then it will be crap. It needs to be done by someone that knows what they are doing.
2, MAF & WAR Chip.
got the potential to be good, but you need to spend time tweaking the chip to suit your engine to get the best out of it.
3, Valves.
cant comment on either, but a good normal grinding wont hurt.
4, Stronger Rockers.
cant make standard ones stronger.
HairyScreech
Post Sun Jan 22, 2012 4:25 am
whats your budget?
aceifty
Post Sun Jan 22, 2012 5:31 pm
HairyScreech wrote:whats your budget?
say about 200
aceifty
Post Sun Jan 22, 2012 5:34 pm
kam-325i wrote:1, Porting and Polishing.
2, MAF & WAR Chip.
3, Valves.
all the work will be done by a professional
e301988325i
Post Sun Jan 22, 2012 5:38 pm
The only person I know who has tried the W.A.R was unable to get the best out of it without creating a whole new map which would have involved hours and hours on the dyno costing ££££££££££££££.
http://www.e30zone.net/modules.php?name ... &start=125
Rockers do break, currently new is the only viable solution, it's worth checking your oil spray bar is clear especially if it was two near to each other that broke.
I said:
e30topless said:
lock the wife in there
HairyScreech
Post Sun Jan 22, 2012 7:03 pm
is that £200 for anything specific or for all 4 jobs?
Post Sun Jan 22, 2012 7:52 pm
I reckon on about £300 in parts/machining just for the minimum amount that's necessary (IMO) when you remove and refit a M20 head!
aceifty
Post Mon Jan 23, 2012 5:27 pm
ill be doing all the work on it including refitting the head, a professional will be doing the porting and polishing, including the valve grind.
i would like to know if it is worth getting the head ported and polished as iv been told its a waste of money to have it polished and if i should do a normal valve grind or a 3 angle valve grind.
200 is just for the rockers. don't really want the standard ones as these is the second time iv had a rocker break in about 18months.
