e36 keeps cutting out..
Pal318is
Post Tue Jan 03, 2012 11:03 am
Hi Guys,
I'm currently using a mates e36 328i, which has developed a problem :cry:
When slowing down or stopping, it keeps cutting out? It's been serviced, and is running nice apart from this problem. In fact since it was serviced, it's been better, but still not great. I've had a look on the e36 forums and ICV could be the problem? When I serviced the car, two of the ht leads (coil packs on top) where slightly damaged at the ends, not sure if they would affect the car at all tho?
Apologies for all the questions and if this is in the wrong section mods, feel free to move..
Pal
Image[img]http://Image
Pal318is
Post Tue Jan 03, 2012 12:57 pm
Thanks diable, they were mentioned on the e36 forums too..
Pal
Fushion_Julz
Post Tue Jan 03, 2012 3:44 pm
could be an air leak in the inlet side or cam cover gasket
1987 Henna Rot M3 (was 195bhp CAT..now more and no cat)
2001 E46 330i SE Touring (manual)
j2b
Post Tue Jan 10, 2012 12:47 am
Had this on an e30 years back , was the fuel pressure regulator,
89 more door 6 pot
dirtybry
Post Tue Jan 10, 2012 1:21 am
Hello,
i had the same problem on my 328i, i first changed the airflow meter and the car drove better for the first week (during the period that the ecu is learning the settings) then the problem came back. i then changed the idle control valve but the problem was still there.
the most common problem with the E36 328i was that the oil brether (attached to the underside of the inlet manifold) would split and let air in when releasing the trottle causing the car to stall.
you can check for airleaks by spraying carb cleaner under the inlet manifold while the engine is running and see if the revs pick up, if the revs pick up u definately have an air leak. its advisable to check the airpipes under the inlet manifold for cracks/splits before changing the oil breather.
I changed the oil breather (approx £70 from the dealers) and the problem has been cured, the car has been problem free for the last 5months :-)
oh yeah, i fitted the old AFM back and sold the new AFM
good luck with yours
bry
lukec88
Post Mon Jan 16, 2012 12:42 am
my e30 was doing this but i had a split in my hose from inlet to AFM. changed that and its sorted it now.
Diamond Schwartz black 1989 325I Sport MTech 2.
Simon
Post Mon Jan 16, 2012 11:35 am
I had the CCV fault on my cousins car, same as dirtybry has mentioned above, causes the symptoms you have mentioned.
