Anyone got some sneaky tips? I've tried the puller method in the wiki:
http://www.e30zone.net/e30zonewiki/inde ... hes#Bushes
and all I did was strip the thread from the threaded bar; the bushes are locked in there tight. Can't really burn them out either, since they're still in situ under the fuel tank.
Advice?
Removing trailing arm bushes
Grrrmachine
- E30 Zone Wiki / Team Member
Grrrmachine
but I knew that picture would turn up again!Grrrmachine wrote:Can't really burn them out either, since they're still in situ under the fuel tank.
I've sort of found a solution; those inch-long nuts that are usually used to join threaded bar together. But I've now snapped three lengths of threaded rod drawing out two bushes; these buggers are wedged in tight!
Prey
admittedly don't know if you can do this in situ or not but if you can get a cordless drill into them just stick a small bit on and drill a few holes thru the bush to loosen it a little - then i had no probs pulling mine out with a bit of m10 rod and a deep 30mm socket. i hate burning them it's filthy, smelly, antisocial, etc etc.
The easiest way by far is to heat them up, you could use the hole-saw method though, once the steel sleeve is out the way its easy to push the rubber out
Mikey_Boy
+1
I ended up cutting pretty much all of mine out when I converted to polybushes...
It is a sh*t of a job - good luck!
+1
redcar
Smack it the sleeve real hard with hammer and screwdriver
It will slip out in one piece
Atleast mine did.
Atleast mine did.
- **BANNED**
Thing is,you need to remove the trailing arm!Grrrmachine wrote:but I knew that picture would turn up again!Grrrmachine wrote:Can't really burn them out either, since they're still in situ under the fuel tank.
Then with it dropped out of the way,if you are to lazy to un-bolt the halfshaft,you have ample safe clearance to burn the bloody bushes out.Replace with polybushes,BTW,as the axle carrier/diff mount are rubber,no harshness is carried into the cabin and you gain from the permanent 'new bush' feeling.....
Grrrmachine
Lazy
The subframe's out, the diff is off, the trailing arms are on the floor with the half-shafts attached. The only thing I haven't disconnected is the handbrake cables, because I hate working on that poxy little tooth wheel through the brake disc. So they're still under the car.
I got two of the foockers out, then broke another length of threaded rod trying to get a new one back in. I even resorted to sex lube to try and get them moving, but I guess Durex Play lotion is as rubbish on cars as it was in the bedroom!
SGP
I held them (with a helper) in a good bench vice and used 2 sockets 1 big one for the bush to slide into and a smaller one to push it through. Only took about a half hour. Well chuffed.
If it ain't broke..
Fix it till it is
Fix it till it is
