How tight should the head bolts be on a M20 engine?
sajad09
Post Fri Jan 06, 2012 4:39 pm
Hi guys,
Can any body tell me how tight the head bolts should be when refiting the head on a M20 B25..
Thanks.. :D :D :D
Post Fri Jan 06, 2012 4:42 pm
Post Fri Jan 06, 2012 4:43 pm
looks like 30nm then 90 degrees each then another 90 degrees using new stretch bolts
sajad09
Post Fri Jan 06, 2012 5:10 pm
Cheers fella :D
Tay
Post Sat Jan 07, 2012 9:26 pm
arrrrrrrrrrrrrggggggggggggghhhhhhhhhhhhh don't worry with new bolts, just tighten them down then 55ftlb is plenty enough!
chh137
Post Sat Jan 07, 2012 9:33 pm
Does that allow for heat expansion and bolts shearing?
Post Sat Jan 07, 2012 9:35 pm
Tay wrote:arrrrrrrrrrrrrggggggggggggghhhhhhhhhhhhh don't worry with new bolts, just tighten them down then 55ftlb is plenty enough!
You pikey, a set of new stretch bolts from BMW is about £25
Tay
Post Sat Jan 07, 2012 9:42 pm
it's all extra un needed expense, and after over a decade of experiance with bmws, i've never had a car back or a bolt shear.
kam-325i
Post Sat Jan 07, 2012 9:47 pm
Its the Hex head bolts that have the shearing problems.
Tay
Post Sat Jan 07, 2012 9:53 pm
i've never had an issue with those either!!!!! lol
sajad09
Post Sat Jan 07, 2012 10:04 pm
I have hex type bolts on mine.
So if i undestand corectlty say i bought new bolts and hand tightened them and then 55ftlb with torqe wrench i will be ok?
Will i have to retighten them again after a while or will they be ok?
kam-325i
Post Sat Jan 07, 2012 10:05 pm
The Hex head ones were factory fitted, I found 2 sheard on mine when i changed head gasket.
standard Retro fitted head bolts should be the Torx fitting type.
Tay
Post Sun Jan 08, 2012 10:34 am
if you use your old ones and pull them down to 55ftlb you won't need to retighten, the bolts end up with extra strain on them when you tighten them 90 and 90 again then re tighten them a few miles down the road.
i've got hex heads in mine with no problem and i've done several others in both the m20 and m30 lumps
Post Sun Jan 08, 2012 10:58 am
IIRC, BMW used hex head bolts from two suppliers at the same time. Only bolts from one of the suppliers are prone to fracture, but there is no way of telling which manufacturer made any particular bolt, so the only way of eliminating the suspect bolts is to replace all hex. bolts.
The greater figure a bolt is torqued up to, the greater the error introduced by friction between the bolt head and the washer under it, and between the threads on the bolt and the block.
If you simply torque up the bolts to a final figure, there will be considerable differences between the true tensions in the bolts, which is the path to warped heads and blown/leaking gaskets.
By initially torquing to a much lower figure, where the friction effects are lower, and then angle torquing, the finished result is much more accurate.
As Tay himself says in another thread " There's a massive difference between a mechanic and an engineer!"
Tay
Post Sun Jan 08, 2012 11:12 am
exactly and there seems to be an abundance of engineers on here at the minute!!!!!
i 100% agree with pulling them down to a lesser torque first before torqueing down to the final torque but i disagree with angle torqueing, this is more prominant on the later alloy blocks as they will only take about 70ftlb of torque before the threads pull out. so once 55ftlb is applyed then by turning the bolt in total another 180 you tend to strip the threads in the block, hense why there are so many about with knackered bottomends. alot of extra stress where it's not needed. i am aware that the m20 is a cast iron block before anyone points that out!
just torque down say 45ftlb then again to 55ftlb and double check and that will see you right.
SGP
Post Sun Jan 08, 2012 11:54 pm
So the engineers advice is to throw the rule book out the window then?
If it ain't broke..
Fix it till it is :)
Post Mon Jan 09, 2012 12:03 am
Stick to what the manufacturer says in this instance and you won't go wrong.
Post Mon Jan 09, 2012 12:45 pm
Make sure you put plenty of this \/ round the old head gasket too, will be good as new :wink:
chh137
Post Mon Jan 09, 2012 1:29 pm
For a more permanent solution would you not recommend "Tiger seal" and do away with any troublesome head bolts ,hexagon,stretch,torx or otherwise?
I do think we need to get upto date and put our trust in modern methods and materials as recommended in some of the posts.
Tay
Post Mon Jan 09, 2012 1:32 pm
No not saying that the engineers among us should do that, but there is a massive difference between the 2, a mechanic does the job with the tools provided and parts available while an engineer wants everything to be precise and done with the correct equipment and all new parts so that all the tollerances are perfect.
I don't know about everyone else here but after all my years experience has shown me that not everyone can afford to replace everything for new. I know I can't! I've just been passing my knowledge on how I see the best way of doing the job with the least amount of money put down! My work has been tried and tested and have never had a car come back that wasn't return business!!!
kam-325i
Post Mon Jan 09, 2012 3:10 pm
A mechanic will know how to do something correctly.
An engineer will know why it has to be done correctly.
Tay
Post Mon Jan 09, 2012 4:25 pm
same same!!!!!!
sajad09
Post Thu Jan 12, 2012 10:28 pm
Thanks for help guys.
Can anybody suggest the best sequence to tighten the bolts in?
Thanks. :D
kam-325i
Post Thu Jan 12, 2012 10:47 pm
the best sequence is to do the correct sequence !
start with the middle two bolts and work outwards clockwise, there is a diagram about somewhere......
kam-325i
Post Thu Jan 12, 2012 10:50 pm
here you go
chh137
Post Thu Jan 12, 2012 10:59 pm
Opposite for removal.
sajad09
Post Thu Jan 12, 2012 11:02 pm
Thanks guys... Appreciate it :D
Post Thu Jan 12, 2012 11:09 pm
you guys use a torque wrench ? I just wait until my elbow clicks :D
HairyScreech
Post Fri Jan 13, 2012 12:50 am
its still not the best thing to do as a bolt set is about £11 from a motorfactors.
Tay
Post Fri Jan 13, 2012 9:20 am
i just use a 3/8 ratchet!
Andyboy
Alpina Colada
Post Fri Jan 13, 2012 6:29 pm
1.) Ignore anything Tay says - he's a bodger who is not to be taken remotely seriously.
2.) The head bolt issue happened on M20's, mainly in 1986-88. They were replaced by the torx stretch bolts in mid 1988 after a spate of bolt failures and BMW were replacing engines left right and centre. They should never be reused, and they should be replaced with stretch bolts. You can do this without taking the head off by replacing them one at a time in the standard sequence.
Tay
Post Fri Jan 13, 2012 7:19 pm
you can just look at my cars if you think i'm a bodger!
when you've torqued as many heads down as i have you get to know the feel of how tight things are! your more than welcome to come and check my head bolts if you wish and i can guarentee they are dead on! and 2.5k after rebuild and no issues........
quezzies?!
Andyboy
Alpina Colada
Post Fri Jan 13, 2012 7:27 pm
Tay wrote: when you've pulled as many knobs as i have you get to know the feel of how tight things are!
EFA, bodger!
GSF do a set of stretch bolts for £17 or something, it's a no brainer if it's recommended they are replaced !!
Dezzy
CR24v it's a lifestyle
Post Fri Jan 13, 2012 7:30 pm
A 3/8 ratchet. You hom! I wouldn't dare, I use a socket, snap-on screwy jammed in and a 10mm spanner off the shank to tighten mine up.
When you talk as much sh1te as me you get a feel for when it's tight. Plus M20 heads never have issues do they?!
What a gonk! :roll:
