Hi Zoners! Hope your all well!
Ive just bought a sunroof motor from a fellow zoner and was wondering how to go about fitting this, i have the front panel aswell with the open/close switch. Any advice wld be brill! Is there any other part i wld need apart from the ones ive already listed?
Thanx
Mitz
Manual to auto sunroof
Ideally, you need the whole motor assembly and mounting plate, complete with the guide tubes.
It's been a while since I did one of these, but there are subtle differences between the backplates for each type, which at first sight appears to be the same for manual and electric.
The three threaded holes that the motor mounts to do not have quite the correct spacing, and there is a difference in height of one of the mountings.
All this can be overcome (and I did on the first one I ever converted), but it's easier to swap in the whole thing.
milescook
Do you have the sunroof motor loom? If not message me I have one spare for only a few notes
Also please help the race budget by watching some videos
https://www.youtube.com/cookracinguk
bmw9818
i did mine few years back when i got my one, you need to remove the black plate, grind the rivet and it should pop off, cant remember how it goes, but once you get the old mounting plate off, just line up the new one, think it just bolts to the rail, bronze peice section,
i think the bolts on the guide rail are the same? i used the manual one,
MIDNIGHT-RACER
I have the loom, thanx bud... Still sounds like rocket science to me.. Lol
Jim320i
- E30 Zone News / COTM Team
I tried removing one the other day. Ended up me loosing my temper and peices being bent up in anger... Good luck putting one in mate!
bmw9818
Lol exactly what I did, pair of pliers bending it to fit, I eventually figured it outJim320i wrote:I tried removing one the other day. Ended up me loosing my temper and peices being bent up in anger... Good luck putting one in mate!
