seat mechanism trouble
Cloggy Saint
Post Tue Jan 10, 2012 1:50 pm
My driver's seat has a problem in that when I recline the seat back it doesn't always catch and it springs back to the fully forward position. I've swapped the mechanism but that makes no difference. I assume then that it's something to do with the flat bar that connects the left and right mechanisms but what can go wrong with this? :?
Post Tue Jan 10, 2012 1:55 pm
Usual cause is a broken seat frame, in turn as a result of one of the seat back securing screws working loose.
Cloggy Saint
Post Tue Jan 10, 2012 2:07 pm
I can rule out a broken frame, it's fine, any other possibilities?
Post Tue Jan 10, 2012 2:18 pm
How are you sure?
Cloggy Saint
Post Tue Jan 10, 2012 2:31 pm
Because I've had it stripped bare for the last month!
Sanchez
Post Tue Jan 10, 2012 3:07 pm
Is it back together properly then?
Cloggy Saint
Post Tue Jan 10, 2012 3:13 pm
I put it all back together and back in the car, discovered the recline function is faulty and now it's back inside in bits again.
Duke137
watching this, my passenger seat does this....
Tay
Post Tue Jan 10, 2012 5:48 pm
sometimes the handle doesn't return to the correct position due to th bolster pressing against it! when you recline it before you let go make sure the handle is in the right position???
Post Tue Jan 10, 2012 7:38 pm
How much of the mech. have you had apart? Have you had the press in bits in the centre of the mech, that transmit the lever's action from one side of the seat to the other, off? Have you had the whole latch assemblies off?
Cloggy Saint
Post Wed Jan 11, 2012 9:09 am
I just removed the entire mechanism assemblies from both sides and replaced them with known good units. When I lift the recline lever the flat bar lifts and the seat back moves but I have to then push the lever down in order to make it bite, and even that doesn't always work.
Post Wed Jan 11, 2012 9:14 am
Why did you replace them? To cure the same fault? If everything is put back correctly, the problem can only be a bent frame if it's not broken.
Take the seat back off, check that both of the spikes that the back sits on are latched by the tilt mechanism, and then carefully place the seat back on the spikes. Both sides should slide in easily and completely, without putting any twist on the spikes.
Cloggy Saint
Post Wed Jan 11, 2012 9:32 am
I replaced them because I thought they could be the cause of the problem. If the frame is bent then it can only be marginal, the seat back slides over the spikes with no problems or wiggling and everything screws up securely.
Post Wed Jan 11, 2012 2:11 pm
Do both sides work reliably, independently of each other, if the back is off?
Cloggy Saint
Post Wed Jan 11, 2012 3:35 pm
No, if the seat back is off and I push the back supports manually they still don't catch.
Post Wed Jan 11, 2012 6:47 pm
It's not the whole latch assembly turning, is it? Are the spring loaded catches that locate them engaged?
Cloggy Saint
Post Tue Jan 24, 2012 10:22 pm
I've decided the fact that the mechanisms are bone dry probably isn't helping things, it's a laboured process for the lever to return to it's starting point. Would good old fashioned grease get things moving again or is there something better out there?
