Diff ratios
randomspeedfreak
which diff ratios are people running on the m42 box?
im going to get an lsd and have been offered a 3.73. should i go for that or hold out for a 3.64 or a 3.46?
whats everyone else got and how does it go?
cheers
cheers
JGTI
I guess a 3.73 might be the right compromise for a quick car off the line, and a useable car!
I'm on 3:91, and it's always buzzing
randomspeedfreak
whats the 3.64 saying boys? anyone got a 3.46?
craigieeb
Im using a 3:64 and it's spot on as an all rounder,
But I wished id used a 3:91
M50 Turbo!!!
I shall say no more
I'll swap you thencraigieeb wrote:Im using a 3:64 and it's spot on as an all rounder,
rich318i
i got a 3:91 but rev's silly
hotrodrick
Im running a 3:91 on my m52 with m42 box and I find it way to short. Need something a bit longer for a daily car. Fun off the lights though!
e30-EVN
I'm using a 3.64 on my m52 with m42 box...... Imo a 3.91 would make take off quite fun but way to buzzy on duals or motorways!
That said a 3.46 would be to long, with the 3.64 I feel its the best all rounder. Not exactly shy off the line either, and 73-75mph @ 3000rpm. Win win
Sanchez
Really depends on your driving style/comfort etc.
3.91 if your not too many motorway miles and lower ratio if your around town or like to give it the beans on the strip/track.
Hoobs
My e21 runs an e12 LSD with a 3:07 and standard 323i box. I plan to fit a C/R gearbox eventually but the longer gears haven't made my car any less fun to drive and it has enough grunt to pull hard through each gear. I quite like not having to snatch a gearchange quite so quickly too!
Rally Prep - Cornwall
ARM BMW & Motorsport
2002
E30 M3 2.3 - Alpha N, C/F airbox etc
2002
shabalake
I've got a 320i gearbox on mine not sure what diff i got but at 70mph its around 3400rpm i looking for somthing longer 3.64?
BATTS91
i have m50 with e36 box and a 4.1 diff ive only test drove down the road and its mental going to try 3.64
redcar
I thought that if you use the e36 box you need something closer to a 3.0?BATTS91 wrote:i have m50 with e36 box and a 4.1 diff ive only test drove down the road and its mental going to try 3.64
hotrodrick
What was the 3.91 lsd originally be fitted to?
redcar
325i facelift sport
Jimbob
Just been playing around with gear ratios here http://www.endtuning.com/gearratios.html
It claims there's 350rpm difference between a 4.10 and 3.64 based on an M42 gearbox @ 70mph, I thought it'd be more than that.
Building a 4.27 LSD seems a bit more realistic now as it looks as though it'll do 3300rpm @ 70mph.
Hoobs
I'm running a 4:1 and was expecting to feel the difference a little more than I do. It does feel better on initial launch but that may simply be that this diff is working better than my old one did?
2002
2002
deanocool
batts i had that symptom. i had a 4.10 that had no 1st or 2nd. i bought a 3.64 but it was still way ott and had 2nd but no 1st. then i got a 3.08 of danthe and its virtually spot on. its a tad light which makes for good acceleration and still has a decent top end. if you want a factory drive i would recommend a 2.93. i wouldnt bother with a 3.64 for a road car on an e36 box, better on a track really.BATTS91 wrote:i have m50 with e36 box and a 4.1 diff ive only test drove down the road and its mental going to try 3.64
