m52 5500rpm problem
rich318i
Post Sun Jan 08, 2012 6:39 pm
i have the 5500 rpm limit problem, new crank sensor and cleard fault memery which was crank sensor and o2 sensor, rev to 6500rpm and now back to 5500rpm. looks like its the o2's.
can any help if this is a normal problem5500rpm with the the 02's not working??
[/b]
e21Jason
Post Sun Jan 08, 2012 6:44 pm
Normally due to an abs fault on e36's as the speed signal for the ecu comes from the abs system, have you always had this problem since the engine swap
BMW e21 track car supercharged s14 cage and fabrication by www.chizfab.com
Z3M Coupe for sale
69 Alfa spyder
Post Sun Jan 08, 2012 6:50 pm
Yep speed sensor issue.
Best speaking with DanThe.
For some reason my M52 ECU is happy without seeing a speed signal, I borrowed an ECU from Dan once and it went straight into 5500rpm limp.
I'm not sure where you get the speed signal from on an E30. I know on later models there is a blue wire which feeds from the instrument cluster which has a speed signal that turns the radio volume up as you go faster
rich318i
Post Sun Jan 08, 2012 6:56 pm
i heard about this problem aswell but never had abs on my e30 it was a m40 engine, and read about pin 20 on the loom and just left it capped off, wire of death ive heard. used to rev up to 6500rpm but also just put the m50 manifold on it when we saw it wouldnt rev above 5500rpm but well rev over 5500rpm if u blip it, but there is 100% no air leaks
rich318i
Post Sun Jan 08, 2012 7:02 pm
have to speck to my mate who wired it up but sure he did that, ill have to ask him just to make sure.
rich318i
Post Sun Jan 08, 2012 8:00 pm
help!!!
rich318i
Post Sat Jan 14, 2012 9:26 pm
e21Jason wrote:Normally due to an abs fault on e36's as the speed signal for the ecu comes from the abs system, have you always had this problem since the engine swap
e34's have the speed from the abs and e36's like e30's get it from the diff
Jacko_
Post Mon Jan 16, 2012 1:42 pm
Sounds lke speed signal issue to me. DanThe can flash this requirement out of the ECU for you as can I and also map for M50 manifold and remove EWS etc.
E21 323i with 2.8 M52 on TBs (fast road / track car)
E28 M535i (track car project)
E36 328i touring (drift wagon daily driver)
rich318i
Post Mon Jan 16, 2012 5:44 pm
Jacko_ wrote:Sounds lke speed signal issue to me. DanThe can flash this requirement out of the ECU for you as can I and also map for M50 manifold and remove EWS etc.
thanks i'll keep you in mind
