The car currently starts and runs nicely with no issues and no smoke.
Much as I would like to do a full refresh -new followers, valve seals & guides, spray bar, pressure test, skim etc whilst its off I'm a bit short on cash so could do without the several hundred quid this is bound to cost by the time everythings been taken into consideration - for starters I understand a genuine headgasket alone is the thick end of £100 without any of the other gaskets needed to complete the job.
So - when a head is removed is it always necessary to get it skimmed ? Or pressure tested ( when it shows no signs of any issues ) ?
Or is it just a case of whip it off, swap the gasket and put it back on ?
I have very painful experience of E30 "while its in bits you may as well......" jobs so could really do without a massive cash outlay on whilst you're at it jobs - but in this case the only bits that are actually knackered are the gasket and manifold studs.
I already have a water pump and cambelt/tensioner to go on as part of the job so no probs there.
Do M20 heads have valve stem oil seals which can be replaced with the head in-situ at a later date if necessary ?
