kam-325i
Post
Sat Jan 07, 2012 4:37 pm
adit
Post
Sat Jan 07, 2012 6:40 pm
there's some work to be done there. same the other side?
[quote="bss325i"]
jimbom30cab
- Tech 1 freak
Post
Sat Jan 07, 2012 6:42 pm
blimey, that's a job not for the faint hearted, should be a fun challenge, wish you all the best with it mate
tonybtonyb
Post
Sat Jan 07, 2012 6:53 pm
good luck mate
kam-325i
Post
Sat Jan 07, 2012 7:46 pm
adit wrote:there's some work to be done there. same the other side?
The other side was not as bad, mainly where the inner arch met the outer arch.
This side is bad because whoever had the car before me covered it all up with filler.....
leeparkes
Post
Sat Jan 07, 2012 8:17 pm
kam-325i
Post
Sat Jan 07, 2012 8:34 pm
that would save me a BIG headache....!!!!
Duke137
Post
Sun Jan 08, 2012 6:32 pm
That panel should help you out Keith, keep the progress coming!
kam-325i
Post
Sun Jan 15, 2012 2:46 pm
Rear bumper removal:
Is it just the two torx bolts that hold on the rear bumper or are there some other clips ?
Post
Sun Jan 15, 2012 3:44 pm
kam-325i
Post
Sun Jan 15, 2012 5:22 pm
Thats off this afternoon, and all is good.
Post
Sun Jan 15, 2012 5:25 pm
Nice one.
Also check the fittings at the top of the wheelarch where the breather "bottle" fits to and the mountings for the filler neck.
kam-325i
Post
Sun Jan 15, 2012 5:30 pm
capri_rob wrote:Nice one.
Also check the fittings at the top of the wheelarch.
No luck there thou,thats all gone.
About an Inch square hole....
kam-325i
Post
Sun Jan 15, 2012 6:23 pm
Expansion Tank Bracket
Behind plastic panel on rear arch
