Please could someone give me tips / advice about an electric passenger window that works very very very slowly and then stops. Mechanism or motor?
Thanks in advance!
325i Cab Passenger Window
Need to know which type of mech. you have. Two completely different kinds fitted to E30s - an 'S' shaped tube with a spiral cable on earlier stuff, and a more conventional scissors arrangement on later stuff.
There was also a dealer fitted windows' kit that is different again, just to complicate things a bit more.
Gavla
Thanks for the response Brianmoooore, I have an 86' 325i Sport Convertible, everything is standard as far as I know, I am the 3rd owner. Is this enough info for you or do I have to pull the door card off?
sweep
i have a mecanism/motor from a 1987 car
Yours will be the earlier type. Clean off all the old hard grease on the cable, replace with fresh stuff, and a little silicon grease for the glass guides, and things should be back to normal.
Gavla
Thanks for the tip Brianmoooore, I will give it a try on the week end.
Sweep, if I end up requiring parts I will let you know.
