325ix wheels interchangable with 325i?
reggid
Post Wed Nov 16, 2005 7:54 am
Will ix's 15x7" basket weaves fit straight onto to my i's which is running stock 14x6.5" basket weaves? Can you tell me what are the offsets for both the 325i and 325ix? In other words is the offst big enough to cause probs.
thanks
buster
Post Wed Nov 16, 2005 8:13 am
i think the IX and the I used the same 15" wheels,just the IX had little plastic arch extensions
reggid
Post Wed Nov 16, 2005 9:30 am
buster wrote:i think the IX and the I used the same 15" wheels,just the IX had little plastic arch extensions
The wheels are 14" according to the tyres on my car and as printed in the manual. I am after some 15" becasue they look just a bit better than the 14" (195/65 Vs 205/55) and want to know whether they fit straight up or whether the offset will cause problems.
buster
Post Wed Nov 16, 2005 9:41 am
direct swap for bmw/BBS 15" basket weaves
Post Wed Nov 16, 2005 6:10 pm
IX X spokes have an offset of 41 whereas standard e30 15" X
spokes have an et of 24 i can't imagine the wheels are interchangeable as that is quite a difference.
buster
Post Wed Nov 16, 2005 7:02 pm
:oops: didnt know that.
pete you clever old bugger,you've probably fragged a 325 ix turd to know that !
The standard 15 " BBS wheels will be a direct swap though.
reggid
Post Thu Nov 17, 2005 1:22 am
so i'd need 17mm spacers to give the correct offset?
What are the downsides of incorrect offset? Rubbing............what else
reggid
Post Fri Nov 18, 2005 11:45 pm
will i need longer wheel lugs?
tomson
Post Wed Jan 11, 2006 1:19 am
Im unsure about what will fit what.
Technically pete is right with his measurements as that is what BMW state. but i own an ix and when i bought it from the fraggers it had steels on.
I have fitted a standard set of 15" x spokes i previously had on 3 or 4 different uk e30s coupe and tourings and they are fine!!
Tom
tomson
Post Wed Jan 11, 2006 1:21 am
Oh,
and i used standard wheel bolts and no spacers.....
