under intake manifold n/s
imye30
Post Sat Dec 10, 2011 8:16 pm
as above there is a connector with pins any one know what is that called for some reason seem to have oil around that area an just above there is a valve well looks like it has a push in pin connector that tube seams to have a leak an has oil marks any one help
Post Sat Dec 10, 2011 8:49 pm
And your engine is?
imye30
Post Sat Dec 10, 2011 9:00 pm
325i from a 1988 f reg
e30-325iS
Post Sun Dec 11, 2011 9:57 am
The connector connects the temperature sensors and injectors to the rest of the harness. Check for corrosion around any of the pins as it can cause all sorts of problems. The valve and tube are the purge solenoid, the tube connects to the throttle body behind the tps. if it is disconnected or has perished you will get a vaccuum leak.
imye30
Post Sun Dec 11, 2011 9:38 pm
can it be re placed
Post Sun Dec 11, 2011 9:45 pm
I very much doubt that you'll find a purge solenoid on a F reg. UK car. This is part of the emissions package, and while these cars were often sold new to people with more money than sense, not many of them ticked this expensive option
