E30 Touring Driveshafts
MrWhippy
Post Sat Dec 10, 2011 3:26 pm
Hi all,
Just having a bit of a nightmare in the work shop, I dont suppose that anyone knows if the drive shafts on a 1993 E30 Touring are the same length for both passenger and drivers side??
Additionally, does anyone know if there is a shaft thats roughly 20mm shorter flange face to flange face that would fit the touring??
Cheers!
HairyScreech
there are medium and small case diff shafts, that may be the problem.
Sanchez
Post Sat Dec 10, 2011 4:04 pm
HairyScreech wrote:there are medium and small case diff shafts, that may be the problem.
Shafts are the same cause the diffs are the same width small or medium case. [/list][/b][/code]
HairyScreech
Post Sat Dec 10, 2011 4:59 pm
oh yeah my bad, its the cups from the diff outputs that are different.
which means all shaft should be the same.
threelander
Post Sat Dec 10, 2011 5:48 pm
simple answer is yes on a standard car
MrWhippy
Post Sat Dec 10, 2011 6:40 pm
Cheers, need to shorten one then. Oh well.....
Post Sat Dec 10, 2011 8:55 pm
Small case output flange on a medium case diff? TBH, I don't even know if this is possible.
Post Sat Dec 10, 2011 9:17 pm
Brianmoooore wrote:Small case output flange on a medium case diff? TBH, I don't even know if this is possible.
Won't work as they are different lengths Brian.
MrWhippy
Post Sat Dec 10, 2011 9:19 pm
Lol supra turbo diff with touring shafts. It's all sorted now, after a long evening of work.
Cheers all.
MrWhippy
Post Sat Dec 10, 2011 9:31 pm
Cheers all.
Post Sat Dec 10, 2011 10:25 pm
Updates? :D
MrWhippy
Post Sun Dec 11, 2011 7:39 pm
DanThe wrote:Updates? :D
In the build thread :)
