Hi all,
Just having a bit of a nightmare in the work shop, I dont suppose that anyone knows if the drive shafts on a 1993 E30 Touring are the same length for both passenger and drivers side??
Additionally, does anyone know if there is a shaft thats roughly 20mm shorter flange face to flange face that would fit the touring??
Cheers!
E30 Touring Driveshafts
HairyScreech
there are medium and small case diff shafts, that may be the problem.
HairyScreech
oh yeah my bad, its the cups from the diff outputs that are different.
which means all shaft should be the same.
- threelander
simple answer is yes on a standard car
- Brianmoooore
Small case output flange on a medium case diff? TBH, I don't even know if this is possible.
- E30 Zone Meets/Events Team
- Contact:
Won't work as they are different lengths Brian.Brianmoooore wrote:Small case output flange on a medium case diff? TBH, I don't even know if this is possible.
