MPG
oze30
Post Tue Nov 15, 2005 12:36 pm
Is there a way of working out MPG from a tank of fuel? I'm getting about 190 miles to about 65l.. Anyone?
I think, if I worked it out correctly, i'm getting about 12-13 MPG :eek: This is for a 325 auto touring! WTF???
max_crox
Post Tue Nov 15, 2005 12:53 pm
Yes there is. :) Well 65liters is about 14 gallon. (But as far as im aware I thought E30's only had 55liter tanks) 190miles divided by 14 = 13.57mpg.
if your work it out using 55liters (12gallon) it equals 15.8mpg. either way thats rather low. Driven carfully you should get about 25ish.
kam-325i
Post Tue Nov 15, 2005 1:02 pm
Some of the later E30's were fitted with the larger 65ltr tanks.
That is a bit poor, i am getting around 20-25mpg with my 325i, most of my travelling is around town.
oze30
Post Tue Nov 15, 2005 1:52 pm
how do I know which tank I have got?
Ziggy
Post Tue Nov 15, 2005 1:59 pm
oze30 wrote:how do I know which tank I have got?
How much fuel can you fit in it?! :lol:
The best way of getting an accurate value for your MPG is to fill the tank up to the brim, reset the trip meter, drive around 'til it's nearly empty & then see how much fuel you can fit in & how many miles you've done...
oze30
Post Tue Nov 15, 2005 2:03 pm
I tried that.. got 178ml.. but not sure if my reserve light goes on or not. I had it down to the red, but no light. I filled up about Ԛ£30 when it was almost to the reserve light.. filled it at approx 90p/l.. How much fuel is in the smaller tank?
Ziggy
Post Tue Nov 15, 2005 4:07 pm
55L - roughly Ԛ£50 quids worth at 90p ish / litre. So if you only got Ԛ£30 in, it wasn't empty!
Ԛ£30 at 90p/l for 178 miles = 24mpg
